Results 1 to 14 of 14
    Apr 2010
    Md
    200 hp Johnson venom
    Hello i have a 200 hp johnson venom and would like to get some more speed or hp out of it ...any ideas? thanks
    Jul 2009
    spokane
    venom
    welcome to scream and fly. maybe start question with year of motor,what kind of hull its on,jack plate , prop, you will find a wealth of information on here but need to be more specific what your looking for good luck
    Nov 2005
    NE Alabama - Weiss Lake
    I have a Venom with a Merc 225 and have so far had her up to 75 with alot more to go. I am running a 28 trophy on a Torquemaster 1.75 LU with a hydraulic jack and have a 1.62 Sporty that will be soon installed - should give me a top speed of 87 with my completely stock 225XS. The Venom hull IMO is the best hull out there and is so easy to drive.
    Sep 2007
    Columbia,AL
    Quote Originally Posted by tj309 View Post
    He meant he had a venom motor not a hydrostream
    Justin Richardson
    Jul 2009
    spokane
    motor
    now thats funny i wasnt going to say anything but
    Jun 2008
    Horsham Pa
    I also have a 200 Johnson Venom and Wrechin2 sent a link to a site where he did one up http://www.chattanoogafishingforum.c...sts=13#M298762
    Nov 2005
    Quote Originally Posted by crimson merc View Post
    I dont see how you got that out of my post. Anyone that says they have a Venom on a site like this is sure to be understood that a Venom is a boat. A Venom is made by Hydrostream and again anyone on this site would know that. If anyone on this site would read a phrase like a "225 Merc" they would also know that an outboard motor was the subject.
    I do not see how you got a "Venom Motor" out of my post - if you read my post you will see that there is no mention of a "Venom Motor".
    Are you high or drunk?
    Sep 2007
    Columbia,AL
    I was high... Khamrick has a Johnson Venom motor not a hydrostream venom.
    Justin Richardson
    Jan 2005
    Fort Lauderdale
    lol. You must be high on drugs that enable you to read questions better.
    Sep 2009
    Santa Rosa, California.
    Deleted by me, not fair. Sorry I was having a moment.
    Steve Schefer
    May 2001
    Hickory NC
    The first thing that will help is to post your actual model number. For added HP a set of 225 carbs will help and depending on year a set of intake manifolds, after that to get a noticable gain you will need to do some port work.
  12. #12
    Apr 2010
    USA
    Remember, you must change the black carb bodies AND the throttle plates together. The carb body/throttle plate set are defined as one set of 225 carbs. You are best NOT to swap carb bodies/throttle plates between years either. '94 carb bodies on '96 throttle plates for instance will not work.
    I have worked on two different V6s this year where someone assumed that the black carb bodies were the only thing needed to be changed. Results are very disappointing, and it is difficult to diagnose...until the fact is accidentally slipped that the throttle plates were not changed out.....then it all becomes clear.
  13. #13
    Feb 2010
    australia
    48cc heads,Big bore v8 carbs,Ported to 90 Degree exhausts 117 intakes v4 stator ,bearing carrier and flywheel......That will give you 300 ish HP on 97 octane
  14. #14
    Apr 2010
    Md
    Bass Boat
    Quote Originally Posted by khamrick View Post
    Hello i have a 96 200 hp johnson venom on a 207 sprint bass boat and would like to get some more speed or hp out of it ...any ideas? thanks
