Results 1 to 15 of 22
Thread: Torque Master lower unit ID?
04-27-2010, 11:20 AM #1
I have a 1998 Mariner Super Magnum 225, I assume the same as a Mercury Pro Max 225, that I am having to replace the seals in the lower unit. Since I bought the engine used, Is there any way to identify the lower unit? I assume it is a torquemaster and not the sportmaster since it has a Bob's nosecone and lwp. The oil drain plug is also under the propshaft. The lower unit does have some #'s on it...U97K1866 and a casting # 847610-0. Just want to make sure I get the right seals.
04-27-2010, 05:16 PM #25000 RPM
- May 2003
- Grafton, WI
- 285
- 40
- 171
Torquemaster Traits
In addition to the oil drain being located below the propshaft on the bearing carrier, 2.5 litre torquemaster gear cases also have:
* Only 4 water intake holes per side
* A cast boss approximately 1 inch in diameter located approximately 4 inches directly above the water intake holes. The boss is drilled and
tapped for a water intake when a nosecone is installed.
* Skeg is cambered on the trailing port side edge to minimize
steering torque when running the engine high.Any fool can make something complicated - it takes a genius to make it simple.
04-28-2010, 12:48 AM #3Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
seal job
prop shaft seals (2) are same as Sporty or late CLE for 1 1/4 dia shaft
carrier oring seal use the red one
water pump stuff is all the same except Sporty has a 3/4 in let on top part on water pump housing which you wont have if its stock stuff off TM
pro marine is oh so much cheaper then MERC on these things prop shaft seals from Merc are jaw clinching numbers for what you get
04-28-2010, 08:03 AM #4
Thanks for the help. You are right on the Merc prices...A couple of prop shaft seals plus shipping will set you back around $50!
08-14-2010, 06:02 PM #5Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
TTT..........
I was aware that the [B]2.5[B]Torquemaster has 4 side inlet holes but are they actually lower down the housing? Also, the skeg on the 2.5 TM I picked up seems strange. It is almost like it is bent but I have never seen a 2.5 TM lower unit until now. Attached is a picture, does anyone recognize this skeg or is it in fact just bent?
08-14-2010, 08:17 PM #6Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
it may be bent but they have the tab thats up set( Curved) and a water inlet boss on the sides for LWP applications
08-14-2010, 11:22 PM #7Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Do you mean like these on the right side?
08-14-2010, 11:55 PM #8Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
torqmaster
the boss on the left side of the pix is where you drill out for the water transfer tube it has them on both sides the others are vent for shift shaft and over flow. its the only case with the boss's in 2.5 class in my opinion its the best case to cone then it turns in to the best coned case on the water
08-15-2010, 05:57 PM #9Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Thanks TEXAS20225,
Here are two better photos of the skeg. Seems to run just fine, but when I look at how straight my Sporty's torque tamer is I just can't figure it out. Any thoughts greatly appreciated!
08-15-2010, 07:55 PM #10Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
its got a little tweek in it but not enough to worry about. not much of a way to fix it without hydraulic press equipment and some body who knows how much to push and when to stop i have straightened them out with heat a big hammer but im cautious about beating on a torqmaster its hard to find them when replacing someones you destroyed
08-15-2010, 08:50 PM #11
08-15-2010, 09:12 PM #12
I have a Titus coned torquemaster and my skeg looks like that too...kinda swept in the back.
08-15-2010, 10:09 PM #13
Here is mine, sorry about the quality they are scans of reg photos.
08-15-2010, 10:47 PM #14Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
i have 2 here at the shop ill get some pixs tomorrow i dont think either one of these are bent or bowed but they do both have the up set style tab not like Sporty or CLE that are cast in but push over by hydraulic force or how ever Merc BENDs them
08-15-2010, 10:58 PM #15Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Thanks guys, I will have to get some play-do from the kids to highlight the bend of the skeg better. It really does look like it was bent which is why I am so concerned. Not looking to end up at the wrong end of the lanyard. It would be good to see some other pics of the same lower. Also, mine has a blow out ring just like my TM. Let me know Dave, H2O and Texas if your lowers also have a blow out ring as well?
