Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    May 2009
    curious... where are you in ca? there aren't many of us on this list.
    -peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
  2. #17
    Quote Originally Posted by larsonblue View Post
    The manual only shows a free-floating pinion gear and a spring and retaining nut.
    The round hub just beneth the (starter drive) bendix teeth is also a clutch. It is there as a safety factor incase the bendix wants to stay engaged with the flywheel ring gear or something else happens causing a bind. It is designed to give incase of undue load etc. More commonly called a Bendix. It operates like this.
    The starter shaft has a helix on it so when the starter spins the Bendix wants to screw up and rise engaging the flywheel ring gear. The spring pushes it back down so the bendix teeth don't stay engaged after the engine fires. The one shown below is a little different only due to the location of the return spring.
    Starter Bendix (appearance will vary)
    <SCRIPT type=text/javascript><!--google_ad_client = "pub-8235759427918457";/* 468x60 Main */google_ad_slot = "5066613839";google_ad_width = 468;google_ad_height = 60;//--></SCRIPT><SCRIPT type=text/javascript src="http://pagead2.googlesyndication.com/pagead/show_ads.js"></SCRIPT><SCRIPT>google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);</SCRIPT>
  3. #18
    Jan 2010
    Quote Originally Posted by HStream1 View Post
    That's it, with the differences you mentioned. It hits the fly wheel hard enough to make a loud noise, which makes me think it might be engaging but then the clutch disengages. However, if I manually engage the gear and then turn the key, it doesn't prematurely disengage. That makes me think the problem is voltage.
  4. #19
    Jan 2010
    Quote Originally Posted by pcrussell50 View Post
    -peter
    I'm in Riverside. For you guys back east that's like being in a different state.
  5. #20
    Jun 2008
    kingman az
    Quote Originally Posted by afr View Post
    i go that one time from a weak battery to if its clean inside try a new bendix spring i think i comes with a new gear to but you wont need that
    i had the same problem...changed the battery and it worked fine after that...also my old battery was freshly charged and put out 12v but we put it on a load tester and it would drop conciderably when something was trying to pull from it
  6. #21
    Jan 2010
    I was thinking the spring might be too stiff, although springs generally get softer over time. I did notice that the pinion gear is only about halfway engaged by the flywheel.
    I'm tempted to turn the retaining nut a few turns so the gear goes in further. It makes so much noise hitting that flywheel I'm starting to wonder if it's bouncing off the retainer and coming back down.
    There's nowhere to hold the rotor so it looks like I'll have to pull the starter to do it. If I have to do that I might as well just bite the bullet and put a new pinion gear in and clean the brushes while I'm at it. Sheesh.
  7. #22
    Quebec. Canada
    Thank's for picture and some advices.. A good forum for trouble shooting..... J-P
    <SCRIPT src="http://pagead2.googlesyndication.com/pagead/abc.js"></SCRIPT><SCRIPT src="http://googleads.g.doubleclick.net/pagead/test_domain.js"></SCRIPT><SCRIPT src="http://pagead2.googlesyndication.com/pagead/render_ads.js"></SCRIPT>
    Go boating,be happy!! And wear safety vest please!! And lesson good music...https://www.youtube.com/watch?v=2c5oHITTI8c
  8. #23
    Gothenburg, Sweden
    Voltage, voltage, voltage
    I still think it is voltage.
    If not, tear the whole thing down, clean it and put it together again.
  9. #24
    Sep 2009
    Santa Rosa, California.
    LOL, yep. I live above the line. It's like being in a different country.
    Steve Schefer
