Results 1 to 6 of 6
Thread: OMC lower unit change?
04-18-2010, 11:31 AM #1Member
- Feb 2010
- MS
- 57
One more time....What year did OMC update/change the lower unit? '92?
04-18-2010, 09:36 PM #2
Pretty sure it was 1993.
NRA Life Member
58' Farmall Cub
Is that your mama's boat?
"I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
04-18-2010, 10:56 PM #3Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Which change are you referring to? drive shaft length was in 92 except the 60 degree V6 was in 91, V8 shaft length did not change
04-19-2010, 12:00 PM #4Member
- Feb 2010
- MS
- 57
Speaking primarily about V6...the lower unit design was changed...it sure helped if one was running the foot high relative to the boat and a surfacing prop...the old style had a big snap ring (lack of a better way to describe) and the recess machined into the foot to receive the snap ring created an area that would crack under the severe duty loads. I think lower unit change happened in early '90's but not sure of the year. The drive shaft length changes you mentioned may be an indicator of when the foot change was introduced on the different models...but maybe not. I would like to get this committed to memory once and for all.
04-19-2010, 12:24 PM #5Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
92 up had the larger prop shaft with a new retention on the carrier but I would still cross bolt it.
04-19-2010, 12:28 PM #6Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
I'm confused on the V4 driveshaft length thing. Will an 84 gearcase work on a 95 motor or is the shaft too long?
