Results 1 to 7 of 7
Thread: carbon tracking
10-09-2002, 07:28 PM #15000 RPM
- Sep 2001
- KC MO
- 602
carbon tracking
'89 200 johnLooking at the tops of my pistons.Two have thick consistant black covering almost the whole piston except in front of the exhaust.One has almost as much.Three have very little carbon spread out inconsistantly.Does this indicate a fuel problem, porting problem?Thanks
CHARGER19
If you're cheap...you got the wrong hobby!
10-10-2002, 12:02 AM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,580
- 18
- 248
- 203
- 462
- 4 Post(s)
Which cylinders have what?
10-10-2002, 12:21 AM #35000 RPM
- Sep 2001
- KC MO
- 602
#2 and 4 have the most.#6 has a little less.#1,3,5 have very little.
CHARGER19
10-14-2002, 04:28 PM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,580
- 18
- 248
- 203
- 462
- 4 Post(s)
With 1,3,5 not having carbon it could be a weak stator as the stator is port/starboard
10-14-2002, 06:16 PM #55000 RPM
- Sep 2001
- KC MO
- 602
It did have a weak stator.It's been replaced but the engine has only been run maybe an hour or two since.Thank you, I really appreciate the help!
CHARGER19
10-14-2002, 07:18 PM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,580
- 18
- 248
- 203
- 462
- 4 Post(s)
You may also want to make sure both banks are at the same temp.
10-14-2002, 07:46 PM #75000 RPM
- Sep 2001
- KC MO
- 602
Can I check that with a thermometer or do I need to use the thermomelt sticks per the service manual?Thanks again!
CHARGER19
