Results 1 to 14 of 14
    Dec 2008
    NOLA
    What do you want in a V drive
    What does everyone here want in a V drive?
    I am looking for features, pricing, specs, etc for a V drive transmission.
    Who's got what and what is wrong with it?
    Please all comments appreciated.
    Northern ILL.
    Quote Originally Posted by FlightService View Post
    To beat a jet boat!
    UMPBA 926 Gas Jet
    May 2006
    New Zealand
    I'd've thought it'd be the same as any other boat... hot, socially liberal girls
    Jul 2004
    Rockford, Mi.
    I've got a comment for you,
    How about re-writing the whole thing so it makes sense.
    21' Eliminator Daytona V-Drive
    1800 HP turbocharged lake boat on E85
    Clock cleaning and wagon fixing
    Dec 2008
    NOLA
    Ok, Unchained.
    Your V drive engages with a thunk, is that ok?
    There is not a PTO on your transmission, do you want one?
    You have to send your transmission back if you want trolling, is that ok or would you rather install it yourself?
    I am asking what features do you want your transmission to have to aid in your enjoyment of our hobby.
    Sleekcrafter: Would a "stall converter" help?
    Jul 2004
    Rockford, Mi.
    I guess you are questioning about an auto trans for a vdrive.
    I have a TH400 that was built by Art Carr in Tx.
    They have a reverse shift pattern and no park.
    I use all three speeds every day. It has worked great.
    You don't use a torque converter. Get a direct drive coupler.
    Just leave the Casale gearbox in forward, With a trans there is no reason to use the in/out shifter.
    PTO on the transmission
    I thought that was how they hooked a hydraulic pump to a dump truck trans.
    Dec 2008
    NOLA
    Auto trans? Now your confusing me!
    Your transmission, gear, mysterious box behind the engine that changes the direction of the crankshaft output to some mystical angle that causes the spinning bar to turn the fan looking thingy, is in all boats, (with the exception of a few race boats that use a direct drive.) This is what allows the boat to go from forward to neutral to reverse.
    Cone clutch units, like Hurth, "thunk" when you engage them. Does everyone who has a transmission that thunks think this is acceptable or just tolerate it.
    PTO is what runs stuff on dump trucks, tractors, work boats, anything that needs power. Anybody have a use for it in their pleasure boat? (A PTO is handy on jet that also need a gear reduction and have a water bucket operated by flow. Nice place to put the pump)
    Marine transmissions don't need torque converters but something that would act like a stall converter would allow the engine to rev a little before fully engaging. Nice for people who want a higher revving small block vs a big block. Helps with the whole shot.
    I hope this clarifies a little more.
    Jan 2006
    macon GA
    My cougar day cruiser has a velvet drive trans from there to a casale v-drive,shifts great.
    Jan 2010
    Detroit Area
    I'm guessing Flight Service is talking about a Ski-Boat Style Vdrive Setup here once he mentioned Hurth.
    Jun 2009
    bradenton,florida
    mine has a car trans r-n-1-2 good for sking, docking ,cruising, and blasting, don't use a torqueconvertor
    Jul 2004
    Rockford, Mi.
    Took me a minute and then I recognized the boat,
    How was your 1st season with that Daytona ?
    That was the deal of the century.
    Got some more pictures ?
  12. #12
    Jun 2009
    bradenton,florida
    1st year good im building a interior in it now.Then will crank up the boost a little .best deal !!!!!!!!! thanks again.
  13. #13
    new york babylon
    A long time ago i had a v drive that klunked!!! i fixed it by shutting off the mota ,put in gear and hit button and off and away,total cost zero,just make sure your mota is in great shape as bat and starter
  14. #14
    Jul 2021
    Edmonton Ab
    Quote Originally Posted by RLP View Post
    Do you still have this boat? I just bought one and haven't found any others through all my searching
