Results 1 to 3 of 3
Thread: merc Lower unit gear ratio
03-27-2010, 09:11 PM #1Member
- Jul 2009
- lacombe la
- 90
I currently have a 3 liter 1.75 ratio lower unit on a light 19 foot
bass boat( about 1100 lbs) I am swinging a 25 pitch yamaha v max prop
at 6000. If I get a 1.62 lower unit will I be able to swing a bigger
prop. I have a 29 yamaha t1 that I would like to put on it or maybe
even more pitch in the future. I am thinking about getting a lower unit
from sterndrive becuase mine is leaking oil everywhere and I didn't
know if I should get the 1.62
Thanks
03-27-2010, 09:34 PM #2
No, the lower you go with the ratio number, the closer you get to 1:1, if you drop from a 1.75 to a 1.62, you will need less pitch to stay at 6000
03-29-2010, 05:13 AM #35000 RPM
- Aug 2009
- chico
- 118
i am not an expert but if you change it 1.62 ratio and your engine have the power to reach the same RPM you will gain more speed.
