Results 1 to 9 of 9
Thread: have to pull off powerhead
03-24-2010, 12:30 PM #1Junior Member
- Sep 2009
- las vegas
- 28
Ah crap! I did my annual two year impeller replacement on my 200 hp efi. Have done this 3 times with no problems. lower unit came off fine, pump went on fine. Started to reinstall lower unit. Found it impossible to put back on, because of a bearing or seal obstructing the powerhead threads. Gonna have to pull powerhead and see what needs replacing. Anyone have this happen before? Also after I pull and fix powerhead, should I install my lower unit first , then try and align powerhead, or should I re-install powerhead , then reinstall lower unit. Seems to me it would be better to install my lower unit first while the powerhead is off, then put powerhead on. Any suggestions appreciated
03-24-2010, 12:53 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
Yep the part that holding the drive shaft male spline from entering the crankshaft female spline is called a Carrier Assembly part number 54196A6 It taps onto the bottom of the crankshaft spline and its got a rubber gasket in the internal part and sometimes they become dislodged and creates the "issue" you are having now ( they block the opening to the female spline on the crank ) ...You might can sharpen a wooden dowel and move the rubber ring in alignment with the crankshaft spline opening..
Just a thought!
JayJay @ JSRE
03-24-2010, 02:18 PM #3Junior Member
- Sep 2009
- las vegas
- 28
Jay; I'll look at it closer today, but it looked like the whole assembly fell down.
03-24-2010, 04:28 PM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
If you can remove it 1/2 the motors I get in here don't have them installed. I order them by the dozens and install before they leave BUT no telling how long they have ran without them just fine...
JayJay @ JSRE
03-24-2010, 05:26 PM #5Junior Member
- Sep 2009
- las vegas
- 28
Thanks Jay!!!! that would have been my next question.
03-24-2010, 06:18 PM #6
Sometimes you can get them out with a piece of welding rod with a hook on the end. Mine came out that way.
Steve Schefer
03-25-2010, 09:32 AM #7Junior Member
- Sep 2009
- las vegas
- 28
That's what it was; the carrier assembly had dropped off. I spent some time trying to get it out but of course the assembly ring is bigger than the hole in the midsection. found a 1/2 inch long pipe to tap it back on the bottom of the crankshaft spline. It seemed to tap back on the crankshaft spline ok. Im sure I can now reassembly my lower unit without pulling the powerhead but my question now is ;before I reassemble the lower/should I try and leave the assembly on or should I try again and get it out alltogether. Any thoughts??
03-25-2010, 02:45 PM #8Junior Member
- Sep 2009
- las vegas
- 28
yah, I will look at it again today
03-26-2010, 11:25 PM #9Junior Member
- Sep 2009
- las vegas
- 28
Thanks Jay & Steve!!
Finally got the carrier assembly out! Of all things, I used a manual sprinkler turnoff rod, bent the end into a small hook. Amazing how easy the lower unit slid on then. Definitely didn't want to pull powerhead. Thanks again for the Info!!!!
