Results 1 to 6 of 6
    Aug 2004
    Venice, Florida
    Rigging tube to Yamaha 130. Clamp for tube at engine?
    I installed a TH Marine rigging tube today to clean up the transom. The motor has a 2" OD rubber grommet that the hose slips over and its snug but not tight. I would like something nicer than a hose clamp or big zip tie to snug it down. Any suggestions?
    I thought this might work well.
    http://www.jegs.com/p/Gates/Gates-Po...43359/10002/-1
    21' Paramount
    Mercury 300 Promax
    Looks like a nice way to end the hose. I can't see any reason it wouldn't work...
    Aug 2004
    Venice, Florida
    The only problem I see with that is its pretty permanent. I think your going to end up cutting the hose if you need to remove it.
    21' Paramount
    Mercury 300 Promax
    Ft. Lauderdale, Fl
    The rigging hose id pretty stiff stuff, I wonder how much force that heat shrink clamp can make. Did you try taking the grommet off and just feeding the hose through the pan?
    Jun 2008
    Ajax
    Aug 2004
    Venice, Florida
    Thats is similar to what I have now but on the engine side, the hose fits snuggly over instead of into the adapter. I may just go with an anodized radiator hose clamp. Cheap bling and will hold it in place.
    21' Paramount
    Mercury 300 Promax
