Results 1 to 15 of 17
Thread: Drag pipe header
03-06-2010, 08:36 PM #1
Drag pipe header
I recently seen a exaust drag pipe setup on liberator21s' post. He had it setup on a 3.0 merc. and I would like to try it on a 2.5!! Anybody else done this if so any info would help.
03-07-2010, 10:03 AM #2
waist of time
03-07-2010, 12:35 PM #3
I guess ur right but it did look cool...... I guess if I can't gain any power then why waste my time!!
03-07-2010, 01:41 PM #47000 RPM
- Apr 2008
- Washington N.C.
- 2,154
I missed that one, I don't know what to say,
03-18-2010, 12:35 PM #5New Member
- Feb 2008
- Tasmania!
Hi,
You need these instead..
Regards
03-18-2010, 07:21 PM #6
Ha!!
03-18-2010, 07:44 PM #7
Someone one here was just talking about a supertrapp muffler on his JohnnyRude...
Mr.Rude has a little Johnson!
Disclaimer: The thoughts and opinions of this member do not always represent those of this forum or those of its members! In the event that your opinions differ from those I have stated, always assume you are wrong and correct your thought process accordingly!
81' Shadow 21 2.5L 200hp Mariner In Resto! (expecting twins)
91' Stratos 274 F/S 150hp Johnson
03-20-2010, 05:01 AM #8
03-22-2010, 09:24 PM #9
I agree, it's fun to do silly things here and there . But how does it sound? Post a vid w/ sound
I started my 650cc Triumph up once in the cellar, I put 2 2" real long copper plumbing pipes on the straight exhaust to get it outside...oh it was loud!
Didn't care what the neighbors thought either."Where is Lee Harvey Oswald, Now that we really need him?"
03-23-2010, 06:33 AM #10
03-25-2010, 11:23 AM #11
Can't wait to hear it run! I wish it was complete when I picked up your old powerhead. I am sure it sounds sweet in person.
03-25-2010, 11:49 AM #12
That reminds me of the Cheech and Chong movie where Tommy Chong has his bike in the living room, and the pipe out the window blowing into his neighbors rose bushes.......lol
Anybody got that clip saved up?
How about John Lentzcow's (sp?) drag motor with 6 expansion chambers hanging off the back>
I heard when he cranked the motor in the shop, it blew everything off the walls.....JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
03-28-2010, 11:21 AM #13
I have got to try this!! I know it sounds awesome!!! Hey it looks like you used cut peices of header.. Then welded to the plate with holes drilled in the mid?? What size hole is in the mid?? Hate to be a copycat but that is cool!! Any info you can give would help!
Hope the surgery turns out well!!!
03-28-2010, 06:44 PM #14
evenpar,
Surgery went well, just sore as hell now, thanks for asking.
The pipes are 1 3/4" OD, 6061-T6 Aluminum Tubing. It sounds pretty good when I had my stock can with a 5" cut off the bottom. I'm now running a new and bigger motor with a HydroTec Tuner, so it should be twice as loud as before........... pipe
I placed my holes in the mid where the most meat was in the casting. Two holes centered off a template you'll have to make in order to get both sides equal and the same. Make a 1/8" thk. aluminum plate to weld the tubes to. When welding the tubes into the 1/8" plate, leave approx. 1/4" of the 1 3/4 pertruding from the 1/8" plate. The 1/4" of pipe sticking out acts as a pilot and helps take any load placed onto the tubes from moving water. The tubes are Tig Welded or welded with a spool gun onto the 1/8" plate from the outside. The assembly is then held onto the mid using 2 1/4-20 stainless steel button head screws.
Hope this helps ya............
03-29-2010, 07:33 PM #15
I'm gonna give a try and i don't think it will be a problem. But I'm gonna use stainless sanitary pipe (very thin and light ) because I have a ton of it. The plate out of 12gauge stainless and maybe cut the tips at a sharp angle to add to the cool factor
Thanks again gary
