Results 1 to 4 of 4
Thread: Transom Knee Placement
03-03-2010, 07:10 PM #1
I've been thinking about this for awhile and would like some opinions from others. Would it be alright to have the transom knees spaced out to each side of the transom instead of connected to the stringers? I would like to have a aluminum tank and be able for it to be under the splash well/deck. I will be decking the transom well also.
Here's what I don't want to do, Would it be ok to space them to the edge of the transom and then bond them to the floor? Would it be strong enough? Thanks
Brandon"Brandon Field"
Formerly Fieldzy
Silly Rabbit, OMC's are for Kids
1982 Hydrostream Vandal, Currently under Resto
03-03-2010, 07:55 PM #2Member
- Sep 2009
- hilton ny
- 65
It would be great if you could make them a little taller even.
The more the better in my opinion..
If you plan on decking off the splash well, you could also tie the knees into that. Thing will be solid.
If you decide to bond them to the floor, It might be wise to bond a small pad to the top of the floor. Maybe like 3"x whatever your knee is. this will help spread the load out a little bit. Should do the trick. Feel bad for the next guy who does the re-core..
03-05-2010, 08:04 AM #3
make sure u dont put them in trhe way of the engine bolts
76 hydrostream viper recored 90 omc
76 ceebee avenger gone
03-05-2010, 08:04 AM #4
an i did mine that way
