Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 108
  1. #91
    Nov 2003
    Simi Valley, SoCal
    I still fix the original Lavorsi pucks. If you have a bad one you want fixed or want to sell one that's bad shoot me a PM.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  2. #92
    Winnipeg
    anyone had to trouble shoot their install as my new autometer procomp just sits at at 30mph. It goes full right, then full left, then sits at 70mph for a second then drops to 30 and sits there
    Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
    Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
    RIP RPM RACING
    RIP GTS1
  3. #93
    Nov 2003
    Simi Valley, SoCal
    Sometimes they take quite a while to acquire a satellite. Leave it on for an hour and see if it goes to zero. It sounds like it's seeing the GPS receiver but not getting the speed data. Probably not a wiring problem.
  4. #94
    Winnipeg
    thanks maybe my grandsport deck is too thick as I have it underneath
    RIP RPM RACING
    RIP GTS1
  5. #95
    Nov 2003
    Simi Valley, SoCal
    I thought about that after I sent the response. When I test antennas after repairing them, I have to put them on a stick out the window of my shop because the roof blocks the signal. Mine is under the deck but may be a thinner deck. I'm sure Kevlar or any metal would block it.
  6. #96
    Aug 2013
    SW PA
    I have a Gaffrig digital speedo w/recall and the battery went bad in the antenna. While looking for a new antenna I came across this thread. So I bought a Garmin 19x HVS. I hooked it up red to power, orange and black to ground and gray to the white wire on my speedo. I'm getting the letters" nsat" on the display. I'm guessing this means "no satellite"? I'm pretty sure it's communicating because if I disconnect the gray the display reads "ndat" and I'm thinking that means "no data". The speedo came with the boat and has 5/06 on the back. What am I doing wrong?
  7. #97
    Nov 2003
    Simi Valley, SoCal
    It may take some time to lock in on enough satellites to come up. If it has a clear view to the sky and doesn't lock on in 15 minutes then my guess would be a data rate or protocol problem. I have never worked on the digital type so not sure what they expect to see for data.
  8. #98
    Aug 2013
    SW PA
    Thanks for the reply I will leave it on longer to make sure it sees satellites also with the orange wire if the antenna is being used for a speedo it always goes to ground right?
  9. #99
    Nov 2003
    Simi Valley, SoCal
    Yes, orange is the enable wire and has to be connected to ground to get a data stream out.
  10. #100
    Aug 2013
    SW PA
    It works! It came with a resistor that I had to put between the orange wire and ground.
    Thanks for the info! This is a great thread.
  11. #101
    Sep 2012
    Branson, MO
    Quote Originally Posted by luv2gofast View Post
    I have one of the Lavorsi speedos that would have used an antenna with a battery (have pics of the back wire plugs under "misc parts for sale" on this sight. Do you happen to have one of the Lavorsi antennas available that you have repaired (installed new battery)? I am trying to sell the speedo but if I don't I will probably keep it.
  12. #102
    I just found one of these on ebay for a bid of 10.50 which I won. I needed a new antenna for my Raytheon 425 chart plotter. Well I hooked it up the same way you would for a speedo and my chart plotter is back in action. I cant believe they discontinued these. What a shame.
  13. #103
    Apr 2006
    Miami, Fl
    Anyone know a replacement antenna that will work to replace the hockey puck antenna since the antenna on the original link is discontinued??? thanks in advance for youir help!!
  14. #104
    Sep 2007
    Epsom N.H
    Quote Originally Posted by speeder4life View Post
    Teleflex makes one that will work. It can be mounted under the deck. Here is a couple links. Any of the marinas can get it for you.
    http://www.starmarinedepot.com/telef...FfNxOgodo0gAxg
    http://www.iboats.com/GPS-Receiver-4...view_id.730635
    My Personal Boats
    1996 STV River Rocket with 260 Mariner SOLD
    1942 Century Sea Maid 17' Split Cockpit Barrel Stern 175 HP Flat Head 6 cyl.
    2004 Moomba Mobius LSV 23' V Drive 345 HP Wakeboard Boat
  15. #105
    Mar 2004
    Lexington SC
    I have a new Autometer 120mph GPS speedo and I bought a antenna that you can hook up either 8 or 16 pulses does anyone know how many pulses a AM speedo is ?????
