Results 76 to 90 of 108
Thread: GPS Antenna ONLY $104.95
02-13-2011, 05:59 PM #76
Does anyone know if a Garmin GA 30 antenna will work with a gaffrig gps speedo?
My Girlfriend ordered me one for Christmas but Im worried that it wont work.
http://www.gpscity.com/garmin-extern...0-antenna.html
06-06-2011, 07:38 PM #77
i need some help guys!!!!! i have the garmin puck that is listed. and the autometer fron the shortcut below.
red to power from the gauge to the red on antenna
black from the gauge to the black on antenna
orange to the same black ground.
white from the gauge to the grey antenna
it just keeps searching for a signal.
here is the gauge link
http://www.danamarineproducts.com/in...GPS_Speedo.pdf
autometer or garmin cant figure it out.... any help would b great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks,
roy93 xr 2001 drag with a 15" drag
92 xb 2002 comp with a 15" drag
R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
07-15-2011, 09:53 AM #78
What antenna do it need ?
this is the gauge that i have
IF IN DOUBT TRIM IT OUT
1986 21`SUPERBOAT W/ECM-300XXX
" The doctor says he's comin , but you gotta pay in cash "
https://www.youtube.com/watch?v=DLBqhpM-AiU
05-22-2012, 07:25 PM #795000 RPM
- Feb 2008
- canada
- 202
I know this is an older thread, but it is today for me. Steve, I bought the gps antenna referred to and pictured above. My Livorsi gps gauge Is a used one I bought on here, so I'm not at all familiar with the original install. I have read that the smaller plug on the back of the gauge is the gps antenna feed. There are three wires coming. Out of the plug itself, being red or and and black. Then, when I look into then other end of the white cable, the cable being a few feet long, I see four wires wrapped in tin foil that actually has what seems like small silver wires wrapped around the outside of the tin foil, then the white plastic exterior. Anyway, then there's what I think is the big recall plug, and I thunk I read somewhere that the red wire on that is actually the DC power input to the gauge. So, knowing all this, how do I wire this thing, if I don't plan on using a recall switch. Stupid question, but do I run pos and neg wires from the battery up to and connect to the red and black wires wire on the gauge, with maybe a fuse in there as well? Then how to connect the antenna?? Thanks Steve or anyone else!
05-22-2012, 09:30 PM #80
Red from antenna and red from gauge to Ignition power. Neg (black) from gauge, Black and orange from antenna to ground. Gray from antenna (GPS pickup) to your gauge GPS pickup (orange??) Couldnt read I think you made a typo. Dont worry about the bare shielded wire. that should do it.
SteveMy Personal Boats
1996 STV River Rocket with 260 Mariner SOLD
1942 Century Sea Maid 17' Split Cockpit Barrel Stern 175 HP Flat Head 6 cyl.
2004 Moomba Mobius LSV 23' V Drive 345 HP Wakeboard Boat
05-23-2012, 07:48 AM #815000 RPM
- Feb 2008
- canada
- 202
Thanks Steve. So, here's the complete wiring rookie in me - when you say red to ignition power - do you mean connect the reds directly to the red prong on the ignition switch? Any when you say "to ground", do you mena the black prong also on the ignition switch itself? Or, am I going to the battery? Sorry, clueless.
05-23-2012, 08:49 PM #82My Personal Boats
05-23-2012, 08:59 PM #83
If your boat is wired correctly, not a given, a purple wire should be feeding your gauges. You can tap in to that for power. Same with the black like Steve says.
06-01-2012, 11:09 AM #84Member
- May 2002
- nc
- 33
Fixed my Livorsi, Thanks.
Red to power, black wire and the orange to ground and gray to pickup.
11-15-2012, 04:27 PM #85
My Livorsi GPS battery went dead in the Donzi a lil while back. Just found these on on ebay and ordered one. Hope It works. Mine has the square plug in the back of the guage. Figured I would share being they had a couple of them left @ $89.95 shipped.
http://www.ebay.com/itm/GARMIN-GPS17...item3a7baa150d
On another Livorsi note.......Been trying for a while now to get some powdercoated cupholders that match my guages and other small items ordered to finish up my Reaction, called several times and left voicemails.. No response or call back. Seems nobody in sales even answers the phone these days. What the hell is up with these people?Smith's Bend Scoundrel
'88/'11 Reaction 19, '88 Merc 200 "Jus' Toodlin'"
'83 Hydrostream Varmint, '88 Merc 200 "Jus Triflin'"
11-15-2012, 04:58 PM #86
is a handheld gps just as good as these mounted units
03-08-2013, 02:21 PM #87
I wanted to ressurect this thread because I am going to be tackling the dead sensor issue in my boat pretty soon here in anticipation of the upcoming season.
The link at the beginning of the thread shows the part as NLA so I just wanted to know what my options were.'72 Glastron GT-150 Johnson Stinger 65
'83 Hydrostream Varmint 2.4 225 Mercury
'05 Hydrostream Voyager 250xs optimax
03-08-2013, 02:41 PM #88
I have a few for sale here. Let me know if you need one.
Steve http://www.screamandfly.com/showthre...enna&highlight=My Personal Boats
06-18-2013, 10:37 AM #89Member
- Dec 2006
- Hemet, Ca
- 30
I know this is kind of old but it seems to be the place to go for info on GPS speedometers and antennas.
Does anyone know if either of these will work? They look the same as the originals on this thread.
http://www.amazon.com/Garmin-Usa-Gps...pd_sim_sbs_e_3
http://www.amazon.com/Garmin-Next-Ge...sim_sbs_misc_1
This is the spedo I am going to get
http://shopping.rexmar.com/Merchant2...ode=AMGPSWhite
Any help would be appreciated
Thanks Erich
06-18-2013, 07:06 PM #90
I got my from Moomba same as the Garmin you have the link for, mounted it under the deck works fine thought the core of my boat
