Results 31 to 45 of 108
Thread: GPS Antenna ONLY $104.95
04-25-2010, 03:27 PM #31
My Garmin 478 has two NMEA 0183 data ouput wires (blue and purple), so I'm going to connect one of the output wire to the S terminal on the back of my Livorsi gauge...that would save me some cash. I'll also have to remember to set the baud rate to 4800 and the antenna to 0183.
04-29-2010, 07:47 PM #32
I connected my Livorsi speedometer to my Garmin 478, set the baud rate to 4800 and it worked!
04-29-2010, 08:07 PM #33
where do I find this ''baud'' rate?
why ask me ?
04-30-2010, 04:46 AM #34
04-30-2010, 09:33 PM #35
okay,since I have just the Livorsi GPS speedometer,I guess I'm SOL>Thanks,anyway,for the response!
why ask me ?
05-01-2010, 07:09 AM #36My Personal Boats
1996 STV River Rocket with 260 Mariner SOLD
1942 Century Sea Maid 17' Split Cockpit Barrel Stern 175 HP Flat Head 6 cyl.
2004 Moomba Mobius LSV 23' V Drive 345 HP Wakeboard Boat
05-01-2010, 03:07 PM #37
I did,but I'm not,it stays on 8 after cycling!
why ask me ?
05-01-2010, 03:24 PM #38My Personal Boats
05-01-2010, 06:57 PM #39Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
I took my first run of the season today and have the same problem. Does anyone have any photos to help visualize the issue? I unscrewed my white cap on the puck, but need to look a lot closer. Annoying as the water was flat !!
05-04-2010, 08:14 AM #40
Moomba,black is to ground,but orange is to acc.on.
why ask me ?
05-04-2010, 03:46 PM #41Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
My unit was also making a low humming sound when switched on
05-04-2010, 06:55 PM #42
Instructions say NOTE The orange (assessory on) wire is used when wiring the GPS 17x to a Garmin Chartplotter, or other NMEA 0183 devise that has a defined accessory signal wire. If you are wiring the GPS 17x to a device that does not have a accessory signal wire, the orange wire from the GPS17x should be connected to GROUND.
This is on page 5 of the instructions. Hope this helps. Mine did not work until I did this. Black and orange to groundLast edited by moomba; 05-04-2010 at 06:56 PM. Reason: text
My Personal Boats
05-04-2010, 07:02 PM #43
thanks,Moomba,I knew if I was a big enough PITA there would be someone here with patience to walk me through my stupidity!!It's really great S&F has qualified answers for all my stupid requests!I appreciate the help[damned old senior citizen!]I'm so relieved to know the answer I think I'll log off and head to the garage!It's sinset here,but tomorrow I'll launch and enjoy!
Thanks again for your help and PATIENCE!!!
Nickwhy ask me ?
05-04-2010, 07:12 PM #44
Mine came the other day but I haven't had time to install. Compared to this, the Lavorsi antenna should cost about $25
16' Inland TigerShark Flatbottom/
1978 Merc1400withXS Mid
coming soon: 2.4 220 Lazer EFI/Marty Powell 15"mid
1988 Weeres 24ft pontoon/30hp Evinrude party barge
1991 STV Pro Comp/Mercury 1996 2.5 260
05-04-2010, 07:15 PM #45
I agree,with three mounting options too!Livorsi uses Garmin so they must charge the middleman's profits!!
why ask me ?
