Results 1 to 9 of 9
02-24-2010, 02:42 PM #1Member
- Jul 2005
- 52
Issue getting water PSI in one engine in quad setup
I have a issue getting water PSI in one engine in a quad setup after installing jackplates. One of the center engines has great PSI while the other will not hold PSI at high speeds.
I installed the Merc scoop/plates which helped a little. The back part of the scoops are not flush with the case facing the props. Could that be an issue? Should I seal this with an adhesive?2009 38TE Fountain with Quad 350 Verados!
02-24-2010, 02:45 PM #27000 RPM
- Apr 2008
- Washington N.C.
- 2,154
You need to talk with Brian Forehand at Fountain, nice guy, and will do all he can to help you..
02-24-2010, 03:10 PM #3Junior Member
- Jul 2009
- Cedar Falls, Iowa
1400 hp on the back? Thats wicked! does raising or lowering engine change psi?
02-24-2010, 03:47 PM #4Member
- Jul 2005
- 52
03-08-2010, 07:27 AM #55000 RPM
- May 2007
- Wright City, MO USA(Transplanted Seattlite)
- 396
Nice boat
This may seem like a stupid question, but.......
How 'flat' is the pad at the rear of your boat?
From your picture it appears as tho all motors are mounted/adjusted to the 'same' height, ANY Vee at the rear of the hull and the center engines could be riding higher in the water than the outers, add that to any 'unbalance' in weight inside the craft, left to right, and it is conceivable the boat could have just a couple of degrees of 'list' to one side with the lower side cooling fine and the 'high' side right at the water line leaving the back of the hull.
IF...... there is any Vee at the rear of the pad then try adjusting the inside motors heights to reflect the same Vee and retest.
03-08-2010, 07:30 AM #65000 RPM
- May 2007
- 396
Is it the port center?
Are any motors CCW?
03-08-2010, 09:34 AM #7Member
- Jul 2005
- 52
The motors in the center are 30s and the outer are 20s
03-11-2010, 12:23 PM #8Junior Member
- Nov 2009
- NYC
- 7
So are you getting cones?
03-11-2010, 12:33 PM #97000 RPM
- Apr 2008
- Washington N.C.
- 2,154
