Results 16 to 30 of 33
Thread: the Cheap choice LQ4
02-21-2010, 04:07 PM #165000 RPM
- May 2009
- FL
- 345
I am talking carb but if i go fuel injection i am sure there is all sorts of info on it i will just need to read up on it and start slow like i said nothing crazy
02-21-2010, 04:57 PM #175000 RPM
- May 2009
- FL
- 345
I think i will go out to Barns & Noble and but this book Designing and Tuning High-Performance Fuel Injection Systems
02-21-2010, 07:07 PM #18
The LS1 books by Will Handzel (here http://www.amazon.com/How-Build-High...ef=cm_cmu_pg_t )are also a good choice.
02-21-2010, 07:55 PM #195000 RPM
- May 2009
- FL
- 345
yup picked that one up to so i got 2 good books
02-21-2010, 11:53 PM #20
The cool part about using EFI on these engines is that the sensors are already there. Reluctor wheel behind the balancer, cam angle, knock sensors on the block, MAP take-off on the inlet manifold and throttle position sensor on the throttle body. And it's all the right gear too, no mixing and matching. We use alot of Delphi ECU's here, just re-flash them with the appropriate fuel and ignition maps. The guys that do ours runs the motors up on a dyno (or couples to a waterjet, same thing) with an O2 sensor and pyrometer to set parameters. Remember, because you will unlikely be running an O2 sensor that you'll have to run an open loop program. Also, unlike your car, the motor is always under load, so a little extra fuel is added and advance removed where required
If the LQ4 and LQ9 are exactly the same, why would they have different model numbers?
02-22-2010, 12:51 AM #215000 RPM
- May 2009
- FL
- 345
Ok but slow down where geting ahead of our self dont have the engine yet and havent even read the fuel injection book all the way through.
02-22-2010, 12:58 AM #22
if you are reading the LS1 book you won't learn ****, it is highly fantastic in ideals... 99% of it is just crap... go to ls1tech.com or performancetrucks.net and get some real good usable info
02-22-2010, 01:00 AM #23
1bad makes a great point about the tuning also, I tune with HPTUNERS which will work in your situation, however... tuning would be much different in technique used...
02-23-2010, 01:44 AM #245000 RPM
- May 2009
- FL
- 345
I am thinking swap the pistons out for some 8 to 1 then twin turbo 14 psi
02-25-2010, 04:34 PM #255000 RPM
- May 2009
- FL
- 345
Well after reading some of my book i think i will use a standalone system that is speed air density
02-26-2010, 01:11 AM #26
Why? Then you'll need a MAF sensor, why not just stick with the MAP. I'll also make things easier when forcing your induction
02-26-2010, 01:34 AM #275000 RPM
- May 2009
- FL
- 345
i must have read that wrong i thought that they did it with a MAP and IAT sensor to figure the air mass entering the engine
02-27-2010, 02:34 PM #28
speed density does NOT utilize a MAF sensor... it focuses on the MAP sensor...
02-27-2010, 02:54 PM #297000 RPM
- Apr 2008
- Washington N.C.
- 2,154
Why not use a ls7 out of a Z06, 470ftlbs 505hp, 7000rpm and you can buy a stand alone ecu from GM.. This would be a cool motor and plug and play.
02-27-2010, 07:50 PM #305000 RPM
- May 2009
- FL
- 345
well the price of a LS7 is realy high in price and a LQ9 with a set of L92 heads and a cam change will put you right around 500 and it is much cheaper but you weigh 88 pounds more.
