Results 1 to 15 of 25
Thread: 1991 2.5 200 mariner
02-16-2010, 09:36 PM #1
im trying to figure out what motor i have.it is suppose to be a 1991 2.5 200 mariner,but some questions have poped up.it has exhaust relief notches and it has 7 petal reeds.can anyone help me please
02-16-2010, 09:46 PM #25000 RPM
- Jul 2005
- Beaumont, Texas
- 779
1991 was the year for the 7 petal reed fishing 200 2.5L.. They are hard to find these days and make great motors.. A little chest cleaning and some 145psi heads and add a 255ProMax ECU and you have a 225PM in sheeps clothing..
Rick2006 Gambler 2200DC/2006 250XS
02-16-2010, 09:50 PM #3
did they have the exhaust reliefs in the sleeves
02-16-2010, 09:51 PM #4
also mine is carbuerated
02-17-2010, 06:33 AM #5
I have a 1991 200 it has 7 petal reeds and exhaust relief in the ports. Sounds like you have a 1991 200 to me.
02-17-2010, 08:00 AM #6
The 91 200 did have the 7 petal front and was made for one year only. Does yours have the water cooled regulator?
Serial #'s OC291520 thru OD081999.Bud Conner "Heathen" "Defending Our Constitution"
02-17-2010, 08:05 AM #7
sounds like a 91, for an all out engine i wouldn't waste money on that block w/ the exhaust reliefs, find a newer block and use all your other parts on it, be careful to, some of the early 2.5/200's were bottom guided and had different rods and pistons
02-17-2010, 08:07 AM #8Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
My XRI didnot have reliefs in tha sleeves, but tha carb motas did(at leest the one I had did)...
People holler about how tha reliefs mota's are junk, but IMO thats BS...Yea, that lil slot will take away a lil compression(and I meen LIL) but I have built relief motas that run juss az good az a non relief mota!!....Unless U are race'in tha mota, and are try'in to git 110% out ov it, thoze slots actually make tha mota a lil more user frenly, and a better idler...JMO
02-17-2010, 08:42 AM #9action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
02-17-2010, 08:56 AM #10Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Well, I did put "River mota" in ther....Lol.........I do actually have sum stock mota's......Wher I live, It's 7 miles from tha land'in to tha Rexaminium, and prolly a mile and a half iz idle zone, so Idle iz kinna impotent on my ride boats....
Tha point I wuz try'in ta make wuz all them ole relief motas ya'll thro away, juss thro them my way!!.....
02-17-2010, 10:59 AM #11
02-17-2010, 08:46 PM #12
thanks
thanks for the feed back.it is a bottom guided motor.it just needs a piston,the cylinders look good i just didnt want to end up with a rebuilt 150 or 175.i feel confident its a 200.ill pick up a little compression with some head work.any other performance tips would be greatly appreciated
02-17-2010, 08:55 PM #13
A 91 was a bottom guided engine.There are plenty of performance tips...Just depends on how far you want to go. You could port to a 245 and add 245 carbs and make it a 245 carb engine. It will have idle reliefs and is not that big of a deal. You have a PM....
James Perry
02-17-2010, 09:47 PM #14
it does have a watercooled regulator
02-17-2010, 09:48 PM #15
how do i get the port specs and pictures of where to port
