Results 136 to 140 of 140
10-30-2002, 06:04 AM #136
pirogue,
give us a final rundown on the finished set-up what exactly have you got now like washer size, diverters (how many) cowl and pan style poppet setup and so on sounds like you got it licked!! good job man!!
10-30-2002, 06:39 AM #137
Yeah...
Give us all the specs on your setup so we can use it for a guide line.
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
10-30-2002, 08:08 PM #138
'93 Pro Max cooling mods
My set up.
1) (4) diverters placed @ 11:00 on 3 & 5 and 1:00 on 4 & 6.
1/4 fuel line used as diverters.
2) used quaters with 3/16 holes in place of thermostats.
3) removed poppet valve guts, and rubber ring around plastic
ring.
4) blocked off wheap hole on poppet valve cover.
5) put dump hose on poppet valve cover.
6) ran a dump off each head.
7) kept triangle hole below poppet valve that runs to center
section open. too much press. when blocked off.
After went test run, had 12psi @ 4000, 18psi @ 5000, 22psi @ 6000. the temp got 125.
The cover and pan is stock and also used stock promax gaskets.
thanks again
I'll help anyone with this set up that i can.
CraigCraig Creppel
DR-20 TRIAD
ALLISON XB 2002
07-27-2009, 12:29 PM #139Member
- Jun 2009
- NY
- 43
09-12-2020, 01:35 AM #1405000 RPM
- Jul 2007
- Appleton,WI
- 238
TTT
Save this one cuz it could answer some of your cooling question.
Good Read with explanations about 2pc Exhaust adator plates vs one piece , how poppit valve works, water diverters in block placment, exct. Even info in here on what OEM temps & water pressure should be at.X-Stream Vegas
