Results 1 to 14 of 14
    Jul 2005
    Crystal River, Fl
    best floor coating?
    im looking to redo the floor of my boat. I was thinking about either white or gray herculiner. Anybody ever tried this or have any other recommendations?
    1986 Laser 380 comp- being re-done... slowly...
    http://www.screamandfly.com/showthre...23#post2859423
    1997 Hewes Bayfisher 16- 90 yammie
    1982 Laser 380- 200 merc- SOLD
    Dec 2001
    Canberra Australia
    2k paint with flattening agent, then sprinkle coarse sugar into it when wet. Once dry, hose all teh sugar out and you have the best non skid ever.
    Because you are creating a coarse finish, you can use a foam roller to put the paint on and don't even have to thin it to roll it, so it's super easy and you get a nice thick coat in one go.
    Regards, Andrew.
    Aug 2004
    Venice, Florida
    Truckbed liner is great but heavy.
    21' Paramount
    Mercury 300 Promax
    Jul 2005
    Crystal River, Fl
    any lighter recommendations?
    Oct 2003
    Sanford, Florida
    Gel or Paint , with a brush and roller . Then sling in another color splatter . A Light Grey , will clean up better then the White will . But it's just a matter of personal prefferance . I'd stay away from the Bed Liner stuff , because it's heavy ,and if you ever need to do any more repair work .
    Rich Martin 018
    HAVE BATTERIES , WILL TRAVEL !!!
    Jul 2005
    Crystal River, Fl
    sounds good! any paint preferences? as for the splatter, you just literally buy another color of paint and sling it on?
    Oct 2003
    Sanford, Florida
    Quote Originally Posted by hawk232 View Post
    Yep , That's how I've done it several times now , on differant boats . Any good quality paint will work . I used an industrial product from Shirwin Wilaims ,that we use at work .
    Take a few test swings at something else before you go at it on the boat , to get a feel for it .
    Good Luck !
    Rich Martin 018
    Boca Raton, FLORIDA
    loncoin rubber floor
    Springfield,La.
    Hold ya splatter brush flat...if ya hold it vertikle, it will make a streak ov splatter, and not spread out like ya want...it'z a piece ov cake!!
    Go ahed and put that bedliner in ya bote...I have anuther 200 U kan bolt on wit tha one ya got, to git ya back up to speed!!!
    Jan 2008
    englewood fl.
    I rolled out white gel in my Vector, then took the boat up to fiberglass shop. They matched the color of my boat,red, and I did spiderweb paint with it. Get a webbing agent to mix with the color matched gel. Use a regular paintgun, very easy and it looks great! Give me your email and I'll send you some detailed pix. Carpet looks so 80's and holds moisture.If you can't find any webbing agent, I think I have enough left over that could send you some.
    St.Cloud, Florida
    When I put a new floor in my son's boat I used a paint from 3m called P51 its a 2 part epoxy, awesome stuff stinks like hell. Only comes in gray and black.
    BLAZER BAY 2400 SUZUKI 250 4 STROKE
    18FT ASTRO BASS BOAT 200 MERC
  12. #12
    Sep 2008
    vero beach
    Took my floor from carpet to painted bottom
    fun part removing carpet, grinding out old glue
    then seal floor with an epoxy sealer
    next picked blue polyurethane (single part enamel)
    and added fine sand for texture
    (and also makes it not slippery when wet)
    "3 coats for total coverage durablity"
    before last coat dries, splatter in second color...
    *note: If using dark base color use light color for splatter
    and Visa/Versa
    Last let paint dry/set for 2 days and reinstall interoir...
    Easy to clean and stays much dryer
    (and thats very important as we all know when dealing with Hydrostreams)
    Hope this helps...Good Luck
    • Hydrostream V-King with a Drag - SOLD
    • STV RR Drag with a Drag- SOLD
    • 18' seacraft c/c 200 merc- SOLD
    • 18' Action Marine Retired & "Wet"
    • STV Needle Nose " The Heat" - SOLD
    • 21' Triad- "The Sipper"- SOLD
    • 26' concept c/c twin 200 Mariners -SOLD
    • STV RR - "Lil Sista" on a Strongback Trailer
    • 18' Action Marine on a Strongback Trailer
    Everybody wants a piece of the pie, till they try it!!!
  13. #13
    Jul 2005
    Crystal River, Fl
    all this helps. right now it has a splatter paint finish with no texture. I am about to move the seats around and do some overall glass work inside the boat and want it all to match, thats why im redoing it. I like the sand idea for texture. did you mix it in the paint or spinkle it on the wet paint? how much paint did it take to do your boat?
  14. #14
    Sep 2008
    vero beach
    Put the sand in the paint and mix...
    This assures that the consistancy is even through out the whole floor...
    No need for sand in splatter...
    Epoxy sealer was 2 part (total of 1/2 gallon) "did not use it all"
    Blue color I used just over a quart...
    and splatter less than a pint...
