Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 114
Thread: vector
  1. #91
    Dec 2004
    Clearwater, Florida
    Quote Originally Posted by Ronny Jetmore View Post
    artie, i was just comparing properties today, and man, i am back on the balsa wagon. like an old girlfriend you keep bumping into, the stuff is just incredible. i am fully convinced now, that on my 13 allison, i will use light weight balsa on transom, core and stringers, with biaxial carbon and pro set epoxy. i will probably vacuum bag, also. just comparing the numbers, balsa is awesome.
    can i ask about balsa on the transom and stringers. if my stringers go to knees?
  2. #92
    Dec 2004
    Clearwater, Florida
    looks like snow
  3. #93
    May 2009
    WEST MICH
    Quote Originally Posted by lightchop View Post
    looks like snow
    I guess so.
  4. #94
    Dec 2004
    Clearwater, Florida
    im setting the boat up on the floor, leveling it up, i have 2x6 horizontal setting in the notch on the transom supporting the stern and supporting the bow near the eye with a notched 4x4 on end. both these pieces have legs to keep them upright,and allow me to shim them one way or the other to get them level right? so the notch in the transom is level. but all the way forward were the bow light goes-i but a level on top, and its off-maybe as much as a bubble. so whats up?
  5. #95
    Dec 2004
    Clearwater, Florida
    went back tried this to the boat- straitend out, all over. i'll try three points see if that helps, otherwise i guess its a wrestling match.
    Attached Thumbnails Attached Thumbnails 004.jpg   003.jpg   014.jpg   015.jpg   019.jpg
  6. #96
    Oct 2009
    Tappahannock Va.
    Man i am in no way a boat builder so i could be wrong in my way of thinking. i recently leveled my vector up for replacement of internal parts with the thought of the running surface being most important. I already had support beams running along the strakes that the floor rests on and supports at bow and outside edges at stearn. I also have it elevated off the floor .
    Attached Thumbnails Attached Thumbnails hydrostream restore under the bow 003.jpg
  7. #97
    Oct 2009
    Tappahannock Va.
    sorry. not used to posting much .
    I started at the rear of the pad thinking everything should be trued up from this point. i shimmed my supports to trueing up, then shimmed front of rails leveling rails rail to rail . then i went to the bow and lifted it to the point where the strakes began to lift off rails with shims. then i added support rails under the pad to true. My vector has the wedge on the pad so i scribbed a 2x4 and cut to match bottom. actually 2 2x4s . I leveled these rails across also at forward part of rails. I didn't realy think leveling the cap would give me a true bottom and did it this way. I also shimmed my two outside supports just to sturdy the boat. just out of curousity i checked the topside for trueness and surpizingly the whole cap was true bow to stearn along with the notch behind pad.
  8. #98
    Oct 2009
    Tappahannock Va.
    Don't know if this will help you any but thought i would share.
    If any of you guys have suggestion on my method please share.
  9. #99
    Dec 2004
    Clearwater, Florida
    nice work.
  10. #100
    Dec 2004
    Clearwater, Florida
    can we hear from the guru's?
  11. #101
    Oct 2009
    Tappahannock Va.
    nice work.
    Thanks man
    being a production boat i realy didn't think the deck cap would be true to the hull is why i did it this way but was surprised as to the results.
    I would recomend using different size levels . I used from a torpedo up to 6 foot. A board with a torpedo could give you false readings.
    Good luck and get er done!!!
  12. #102
    Dec 2004
    Clearwater, Florida
    dis my level, it was at home-i know torpedo are only ok. i'm checking this out. top of the bows off maybe half bubble or less. where the deck lays its on.
    Attached Thumbnails Attached Thumbnails 001.jpg   002.jpg   007.jpg   019.jpg   016.jpg
  13. #103
    Dec 2004
    Clearwater, Florida
    one more-im not boring yu people am i?
  14. #104
    Dec 2004
    Clearwater, Florida
    being quite now........ seeing if the'll mate.
  15. #105
    Jun 2009
    Bristol, Connecticut
    Not boring at all! Keep posting any pictures you have, I'm taking notes for my core job!!
