Results 1 to 5 of 5
    May 2002
    Columbus, OH
    Prop removal and installation / thrust washers, tab washers, etc.
    So I bought a new (to me) Hydrostream Valero with a 1995 2.5L Mercury offshore engine. The second time out I get the prop in the lake bottom and bend up the ears I have sent the prop off for repair but have questions about getting the thrust washer off.
    The one on the prop shaft is 3/4" thick and doesnít have the step design I have seen on the boards. It is approximately the same diameter. What is the best way to get it off? I am a bit leery of taking a ballpene hammer to it.
    When replacing it what thrust washer should be used (part number). The prop a Mazco re3 28p that came off only had a nut and a tab washer. It also had what looks to be a thrust washer with grooves for the tab washer built into it.
    I have another prop I would like to put on the boat so I can get some more use out of it before the end of the season. This prop doesnít have a flush front, it has what looks to be a washer in the insert that sticks out about an 1/8". The back is recessed some with room for a washer tab washer and nut. Itís a stainless steel prop with a similar hub design as the Mazco.
    Suggestions on the removal of the existing thrust washer and parts to install the other prop (and the Mazco when I get it back) would be appreciated.
    If need be I could scan the prop in questions.
    Thanks,
    Steve
    Aug 2002
    New Ulm, Mn
    You should just have to give it a tap with the hammer and it should be loose.
    Allison XB2002/260 SS
    umpba.org
    riversidegarage.com
    Jun 2001
    Sylvan Lake, MI.
    Tap the thrust washer face closer to the outer edge. Use a brass or aluminum hammer.
    I use the Merc stepped thrust washer with all my props. Merc, Mazco and Power-Tech.
    Dennis
    May 2002
    Columbus, OH
    Thanks, I will get a brass hammer and give it a try.
    Jul 2002
    Calais, ME
    YUP!
    The propshaft is tapered where the thrust washer comes into contact with it so all you have to do is tap it and it will come loose.
    ------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
    "Life is short - Get there fast...MERCURY"
