Results 1 to 4 of 4
09-29-2002, 09:40 AM #1
Need a little help with gearhousing.....
Here's the scene. Bought new gearcase from a dealer liquidating. It already had the lower driveshaft roller bearing in it, but it was the wrong one for my shaft. Using the SPECIAL MERCURY TOOL I tried to press the bearing out. The entire bottom of the outer race bustted out and the bearings fell in the housing. Problem! How can I get the outer race out? I tried a little heat, but nothing to get a grip on inside the housing to knock th race out. Anybody got a suggestion? I got a new housing and can't use it.
Thanks,
DaveHave you ever stopped to think............and forget to start again?
09-29-2002, 12:14 PM #2
This is a test
It is only a test, do not adjust your monitor.
Rickracer
Sunshine Syndicate Member
There is a fine line between "hobby" and "mental illness."
[img]http:/
09-30-2002, 11:33 AM #3Junior Member
- Sep 2002
- brunswick, ga
- 28
two ways to do it, not going to tell you the first bad way to do it in less all else fails. get some 1/2 inch sockets and find one that will fit in the housing hole and also grab the race, I`ve done it before not to hard,good luck but you won`t need it . mike
10-01-2002, 01:23 PM #4Member
- Sep 2002
- SIKETON, MO
- 86
gear case
superdave
if you have not already gotten the outer bearing race out
you can run a weld bead on the inside of the outer race let it cool and then about 30 min. turn it upside down and it will probably fall out.
stanHE WHO DIES WITH THE MOST TOYS, "WINS".
