Results 121 to 135 of 136
Thread: Reeds
06-03-2012, 03:34 PM #121
Very Strange
I find it very strange that the most important post in the entire 8 page thread is missing.
But, never fear, ole Forkin' saved it on his computer!!!
Originally Posted by racer
texasvector, aj06bolt12r thanked for this post
06-03-2012, 04:54 PM #122
You rock my Brother! Spent 20 mins trying to clean mine up so you could read it w/no success.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
06-03-2012, 05:48 PM #123
Al Stoker spent way too much time and money on this project for this to just disappear. I am surprised and a little bothered that the KEY post went "POOF".
Thank you again Al Stoker (racer) all for your restless dedication! We all appreciate it!
PS I copy a lot of stuff!
06-03-2012, 08:15 PM #124I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-03-2012, 09:30 PM #125
Jay didn't mean to get your panties in a wad,thats a great offer.
Forkin that a good save thanks,a lot work went into that would have been a shame to loose it21 SuperBoat VF200 Yamaha SHO
06-03-2012, 09:38 PM #126
06-04-2012, 09:57 AM #127Supporting Vendor
- 11,838
- 163
- 11
- 795
Superbender,
At 60 years old it would take a lot more than a post on a forum to raise my Blood Pressure ! Too busy building motors and installing TDR reeds LOL.... But thanks for the concern.. Try a set of TDR's you'll be glad ya did..
JayJay @ JSRE
06-05-2012, 01:30 AM #128Markus' Performance Boating Links:
06-05-2012, 01:46 AM #129
On my HST, I noticed that when I switched my Boysens to CCMS .022" reeds and his 1" spacer, I had to bump the idle mixture on the ACU richer as well as the sensitivity and compensation adjustments as well. 4-6% on all three.
After the change, it wouldn't really run through the no wake zone from the launch without bumping the enrichener. Trying to get it on plane, I had to do the same. Two quick adjustments and it's almost there. I just have not had time to play with it any more.
So far so good. The real test for me will be how well it pulls over 7500.
I will post results when I play some more.The Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
06-05-2012, 04:31 PM #130
Well I have never put a set of boyesens in a motor and not seen an improvement in idle quality and punch. But I used them in OMC's so, your results may vary. The ones that came out of my eagle motor looked good to me, so they went into my franken eagle project motor. So far so good.
Since these are on rubber coated ficht cages, they should last forever.
06-05-2012, 05:58 PM #131Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Ronnie,your running lean for two reasons
1. You are getting more air...
2. The air is staying in the crankcase,and less is refluxing back into the airhorn,carrying fuel with it,richening the mixture by causing the motor to re-breathe air with some fuel already in it.Same applys to a carb motor,the airbox traps one cylinders reflux,and then the cylinder next door sucks it in,and in turn spits a little out...the better the reeds flow and seal the leaner the mix,Chris
06-05-2012, 06:27 PM #132
I talked to Tony Brucato and he said the same.. It is probably creating more vacuum now too.
I am using the Boysen hold downs with no stops, is this correct Chris?
I'll tell you one thing; that thing cold starts now better that it ever did. It used to be a real pain, especially at a packed launch, looking like a newb trying to start it.The Reverend, (Cedar Machine Service on Facebook)
1977 Viper
06-05-2012, 07:44 PM #133Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
The stock ones are a little thicker,boys are thinner because with both layers you have around .050 in reeds stacked up,they needed the thinner plates to get them to fit... It'll most likely be ok,Chris
06-05-2012, 08:54 PM #134The Reverend, (Cedar Machine Service on Facebook)
1977 Viper
06-06-2012, 03:32 PM #135
