Results 31 to 45 of 136
Thread: Reeds
02-01-2010, 01:29 AM #315000 RPM
- Jan 2007
- Tampa, Fl
- 167
I just rebuilt my stock 200 XRi and heard about Chris's reeds on here, called them as just googan on the phone with a stock engine and I can't imagine anybody taking more time to talk with me. I put them in and it purred like a sewing machine and was it so quiet I joked I thought I bought a 4 stroke. Still in breakin time so no WOT - its cold has hell in Fla too, bad enough just getting on plane I think I need gloves.
1976 SeaCraft Master Angler - 200 XRi
02-01-2010, 07:39 PM #32Junior Member
- Aug 2009
- louisiana
- 29
reed test
well guys i have tested the reeds and the reeds was tested 2 diffrent days and once at 11:00 and once at 2:00 on a sat and a sun and the chris carson turned 150rpms top end than the stock and my stock turns more than the hydro tec reeds the test was done 2 diffrent days to see what the average was and there it is guys thank you chris you have a great product, and all 3 reeds was run back to back 2 diffrent days so it would be fair and this is what the results are thanks again chris
02-01-2010, 10:43 PM #33
what as your jet
Changes?
02-02-2010, 04:56 AM #34
like is already stated, i think there are too many other variables that make swapping a set of reeds then testing power output kinda pointless... unless you could run a setup that would guarantee a static air/fuel ratio. Some auto ecu's can do that these days - possibly on 2 stroke?
If only there was a flow bench that could simulate the crankcase pulses/conditions - i take it there isnt?Last edited by gmacrae; 02-02-2010 at 05:01 AM.
02-02-2010, 07:53 AM #35
There are no flow benchs that I am aware of that can duplicate the pulses.
I rode the Louge in Rotorua a few years back. That was fun.He who "HESITATES" has Lost.
02-02-2010, 08:06 AM #36Supporting Vendor
- 11,838
- 163
- 11
- 795
Can't wait until Tony @ TDR finishes his write up on reed valves... (30 years in the reed business) Gonna be VERY informative, with LOTS to be LEARNED by ALL...
JayJay @ JSRE
02-02-2010, 10:35 AM #37Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Dr Blair made one once ( its in an SAE paper) with a rotating drum with a pipe through it so it makes and breaks the reed box as it rotates as there is low pressure on the other side.
I guess it was close to the pulsing as you would get in the lab
I'll see if I can find the paper
I do remember the reeds closed and opened at all rpm'sLast edited by powerabout; 02-02-2010 at 10:42 AM.
02-02-2010, 11:23 AM #38Banned
- Dec 2002
- 3,521
What good does the reeds do over 10,000rpms?
02-02-2010, 11:59 AM #39Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
lets see someone pull a reed off and run to 10k on a dyno and see if it still makes power?
02-02-2010, 01:49 PM #40Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
powerabout,Its pretty much common knowledge when you break a reed{same as leaving one out}you slow down...wether you'r turning 6,7,8,9,or 10k plus,no matter,I don't think anyone will argue about that.Anyone who builds ultra high perf motors I believe will tell you the first sign of a broken reed is approx a 1000 rpm loss.Really shouldn't need a dyno test to prove that,,...Reeds not opening and closing at high RPM's in my opinion is right there with the boogy man and the Flat Earth Society,Chris
02-02-2010, 02:05 PM #41
But what about the boiling mud?! you saw the boiling mud right?!? hehe
These days its so tame, years ago when there was only one track it was pretty narly, brutal drop-offs and jumps, massive high speed burms. A few broken limbs and spine injurys later they took out all the good bits and added the scenic/learner tracks - ahhh good bless the '80's
02-02-2010, 02:17 PM #42
02-02-2010, 02:35 PM #43Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-02-2010, 03:11 PM #44
02-02-2010, 03:14 PM #45Junior Member
- Aug 2009
- louisiana
- 29
reed test
that is y i tested 2 diffrent days and twice one day and twice the next i wanted it to be even ground and the results was 150rpms for the chris carson reed i do not have a dyno but i tested on the motor with both days and thats how i did it and the results was the same
