Results 16 to 30 of 136
Thread: Reeds
01-25-2010, 10:03 AM #16
01-25-2010, 10:15 AM #17
I'd love it.
I'd ask that a baseline be determined with stock reeds first and stock reeds retested at the end to show nothing changed (wear in, etc) and that the dyno's results are really tight.
There is a chance that we would all learn something. Education is a good thing.
01-25-2010, 10:28 AM #18
One last note:
If you test 5 brands of a product and you post the results, you will have 1 friend and 4 enemies. As well as all their followers. The main issue is that most of the comments are from the average Joe that has not had the privledge of having all the knowledge, & testing equipment.
It takes a lot of guts to post results knowing that you are standing in the flack zone. Trust me I have been in the Flack zone many times.
Good job, Test away, looking forward to the results, and if you need any information at all, please contact me direct.Last edited by TDR_50; 01-25-2010 at 10:44 AM.
He who "HESITATES" has Lost.
01-25-2010, 10:41 AM #19
Its also possible to have 5 enemies
01-25-2010, 10:51 AM #20
This is true.
Learning is a never ending process.He who "HESITATES" has Lost.
01-25-2010, 11:52 AM #21
Al, this "controlled" testing can be very helpful in choosing proper reeds for an application. My "dinosaur" testing methods are for nitrous use only and proir to actually trying a set of TDR's I was using "home made" reeds (we already knew what material and thickness worked). From Dec 2008 till August 2009 I ran the same set of TDR's without a glitch (they still look good after being hit with a bunch of nitrous) and wanted to try Carson's reeds. So far the Carson reeds are holding up well under the same harsh treatment that the TDR's went through.
I agree, and I was warned of this from some very knowledagble racers/engine builders when I first started racing. My ass got tore up quick by the hungry alligators that have nothing better to do than talk chit but I keep on testing and blowing **** up.
Kaase Outboard Hydro/Bottle Fed 300 Drag
01-25-2010, 11:58 AM #22
01-25-2010, 01:39 PM #23
Also What other brands are going to be tested. So far we have:
Stock reeds
Chris Carson reeds
TDR Reeds
Lets hear some other brands.
I think Boysen reeds both the racing version and the standard version.
Keeping that in mind:
Standard long life reeds should all be grouped in 1 catagory and ultimate performance reeds in another catagory.
Question #1 is :
Do you want the best performance and they will last only 1 race day.
Do you want good performance but less HP and they will last for seasons.??
Both are available from all the vendors.Last edited by TDR_50; 01-28-2010 at 06:58 AM.
01-25-2010, 02:06 PM #24Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Tony brings up a good point as to usage. This is the reason I would like to do it this way, tell the manufacturer its use and expected life as a customer would and take that manufacturers recomendation and test it. The one problem with doing this on an omc is the time needed to change them out, this means the test will take a couple days. While we can control things to a point we will need to rely on the dyno weather station for proper correction factors, it may also mean testing days apart to keep the factors inline. Keep in mind this is a follow up test I dont have time to test every available reed.
01-25-2010, 03:47 PM #25
Al, you may be walking into a hornet's nest, but I would sure like to see your results.
I also have a test mule for you just sittin here!
(I'm sure I already know the answer to that)
01-25-2010, 10:53 PM #26
c what u got
I can already tell u number 5 (with the dip tube in it),needs 2-b up 3 (on jets),number 1 up 2.
01-28-2010, 02:03 AM #27
I would rather read a post (if there is not already one??) on how to build a RELIABLE 3.0 with 300 + hp on pump gas as we know Al is pretty much the best at it..
Sorry to disrupt the post
I beleive aslong as you stick with the main brands of reeds, you aint going to see any noticable improvment over each other..
Dave G.
Injected OMC 3.3 Motec Ignition
MAD 16" Mid
Sporty
01-29-2010, 01:16 AM #28
Nice!!
Isn’t that the truth!
Because of chipping, I have been using G10-FR4 and had custom sets cut for The evolution and Taylor cages due to the proprietary sizes in their designs.
Actually numbers from an automated Dyno would be yet another Gift from the Gurus! Thanks again Al!!2006 Action Marine Comp
1980 Ventrua 2
01-29-2010, 09:41 AM #29
get going
Let's go,geT'r done.
01-29-2010, 10:13 AM #30
Subscribed to learn... go for it al
1990 hydrostream virage diamondpower280
