Results 31 to 45 of 46
Thread: *Sigh* I'm going to ask.....
09-11-2010, 05:25 PM #31
I must be retarded. I thought a GT200 was a 2.6
-Dustin
17' Action Marine - Merc power
09-12-2010, 11:09 AM #32
Taking it up to 2" below the pad is not what the shooter liked at all. Time for a prop change no doubt.
-Dustin
09-12-2010, 06:22 PM #33
A 2.6 would be a 175 or 235 crossflow. You either have a 2.7 or 3.0 since you have a looper.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
09-13-2010, 12:52 AM #34
Quarterhorse, you should try a 28 Offshore cut it will give you everything you need.Peace steve
Steve Smith
Shepherdsville, Ky
502-693-3273
Click Link to Visit our Website at
http://www.sdspropshop.com
09-13-2010, 06:54 AM #35
On my last OMC motor I ran a Raker and was pleased with the performance.
'72 Glastron GT-150 Johnson Stinger 65
'83 Hydrostream Varmint 2.4 225 Mercury
'05 Hydrostream Voyager 250xs optimax
01-04-2011, 12:14 PM #36
Lets throw a wrench in on this thread. Popped the OMC, I now have a 2.5 200 fishing motor Merc. Suggestions the same you think?
-Dustin
01-04-2011, 12:24 PM #37
I've got 2 for you to try Dustin...just let me know....my DAH 26P MACH chopper and a 28P A5 small ear thats sittin at DAH right now getting "fixed". You will most likely want a 14 1/4" or 14 1/2" diameter over the 14" props i'm running but playing with as many props as you can get your hands on isn't a bad thing.
Theres a whole bunch of props to be had around here if you get back this way I'll compile some for you. OR you could make it to a Power Tour stop and have a whole bunch available to you there too.
I agree, SRX will most likely be your go-to wheel once you find out what the boat wants and get it worked on to do what you need it to do.1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
01-04-2011, 12:37 PM #38Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
God, Country, and Fast Boats
01-04-2011, 01:36 PM #39
I have had great luck with my 25 Trophy for an "all around" prop". With that prop on the boat and the motor 1" under the pad I can pull up a wakeboarder with 3 people + gear in the boat, or drop them off and still run close to 80 with the same setup. I also have a DAH worked 27 SRX....great all around prop if it's just me in the boat, but when you start adding people and gear, I like the trophy better.
I have ran several different types of Shooters, Renegades, and Rakers.....and they all slipped pretty bad and low speeds unless I dropped the motor down another inch or so. The Trophy was the only prop I've found that has great bite at slow speeds even with the motor relativity high.Last edited by imq707s; 01-04-2011 at 01:39 PM.
Ian
...boatless for now.
01-04-2011, 03:58 PM #40
The same props suggested for your OMC will work the same with your Merc. I really enjoy my 27 SRX for all around use. I also run a 30 MACH chopper that gets my best top end speeds. I use a 27 Renegade 4 blade to pull wakeboarders but a lower pitch prop would be better for pulling skiers out of the hole.
01-04-2011, 04:11 PM #415000 RPM
- Dec 2005
- mid ga
- 333
my first vector with a 235 i ran the propshaft even with 4 in setback, a 29 spinelli for up and down the river and a 24 small ear chopper for pairing off , later, in both my varmints with merc power , i think its the same bottom, ran the same spinelli but had to step up to a yamaha style 24 for the drags
01-05-2011, 02:43 AM #42
01-05-2011, 09:30 AM #43
27 srx is hard to beat for an all around prop.
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
09-18-2021, 08:54 PM #44Junior Member
- Feb 2020
- CA/TX
- 11
Soinelli
I would call Doug at Spinelli 315-594-2229
09-19-2021, 07:19 AM #455000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Cat - this thread is over 10 years old -
