Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
    May 2007
    Des Moines, Iowa
    *Sigh* I'm going to ask.....
    I hate to ask as I'd rather buy several props, but lets be realistic. That can get spendy, I don't have friends with boats as light and powered like mine is going to be, so borrowing props isn't available.
    I'm working with a full interior Vector and a rebuilt 200 V6 Johnson that won't be much more HP than stock right now. Pleasure boat first, race second. I have a ROUGH 27p 4 blade shooter. If I were to buy a good all around prop what would you suggest?
    I see lots of suggestions for choppers, but those are good for bow lift, and I wouldn't think I'd want any more than this boat is going to have with the big V6 out back. I don't want a Cleaver as I'll have medium load on most of the time, and top speed runs will be minimal I'm sure.
    Sorry for asking the question, I just don't have the cash/resources to do my own research.
    Thanks
    Dustin
    -Dustin
    17' Action Marine - Merc power
    Montgomery MN - Abu Dhabi UAE
    I would start with a 27 srx. Someone was just selling one worked by DAH.
    Chet Olson
    Pekin, IL
    You are about 5 hrs from me. This spring you could tow over and try several props. I loved the chopper on my Streams.
    Rock
    Team Junk
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    i like the choppers... i really like the 30 chopper II i ran but i ran a 26 srx on my vking with a 140 and it would run pretty good... if you are gonna have the whole family in the boat then i would go with a 26 27 srx or chopper... the choppers have good bow lift so
    Mirage RR
    Lake Tarpon Boyz!!!
    May 2007
    Des Moines, Iowa
    You don't think the Choppers would have too much bow lift and want to blow over with a heavy V6 out back? SRX's are similar to Choppers as they lift the bow correct?
    -Dustin
    Nov 2007
    Quote Originally Posted by QuarterHorse View Post
    yeah i had my v6 (right at 300hp) on my action and the 30.. the action packs a bunch of air as it is cause its got such a wide bow and i liked it alot on it... it wont be too much if you dont let it
    Mirage RR
    Lake Tarpon Boyz!!!
    May 2007
    Des Moines, Iowa
    It's a good thing this hull came with dual cable steering and a hot foot lol.
    -Dustin
    Nov 2007
    i ran hydraulic on my action but the hot foot is a must if your wanting to go fast...
    Mirage RR
    Lake Tarpon Boyz!!!
    Oct 2003
    Cobourg, ON
    QH you will want more than one prop. They hold their value so don't worry about getting rid of one if it doesn't work for you.
    Lannon WI
    Your first wheel should be a 27srx, or 26-28 chopper, mazco, spinelli ect...
    Then SHow your A$$ up at an event with a smile and I would bet youll be able to try a few...
    2006 Action Marine Comp
    1980 Ventrua 2
    May 2007
    Des Moines, Iowa
    Riverman - Thanks, I just didn't want to buy one that sat on a shelf and loose too much coin.
    Laker - As soon as the boat is done and the weather turns you bet your last dollar I'll be up there when I know where one is at!
    -Dustin
  12. #12
    Fenton Michigan
    If I had your boat and could buy only one prop it would be a 27 SRX built by DAH for a Stream. They are easily bought here in S&F for under $400. It will carry a load accelerate well. You can even pull the kids on a tube with it. A 27 Trophy would be my second choice and a stock chopper third. The Trophy is an awesome all around prop.
  13. #13
    May 2007
    Des Moines, Iowa
    Thanks Wizard, it seems the SRX is the one that keeps coming up in each post. I'll do some searching for one.
    I did forget to mention I have a 6" jackplate on the boat as well, not sure if it makes a difference in the suggestions, I just forgot to mention that.
    -Dustin
  14. #14
    Jan 2008
    englewood fl.
    A big ear chopper with an offshore cut works well.
  15. #15
    May 2007
    Des Moines, Iowa
    Sounds good, I'll keep my eyes peeled.
    -Dustin
