Results 1 to 15 of 46
Thread: *Sigh* I'm going to ask.....
01-22-2010, 07:29 PM #1
I hate to ask as I'd rather buy several props, but lets be realistic. That can get spendy, I don't have friends with boats as light and powered like mine is going to be, so borrowing props isn't available.
I'm working with a full interior Vector and a rebuilt 200 V6 Johnson that won't be much more HP than stock right now. Pleasure boat first, race second. I have a ROUGH 27p 4 blade shooter. If I were to buy a good all around prop what would you suggest?
I see lots of suggestions for choppers, but those are good for bow lift, and I wouldn't think I'd want any more than this boat is going to have with the big V6 out back. I don't want a Cleaver as I'll have medium load on most of the time, and top speed runs will be minimal I'm sure.
Sorry for asking the question, I just don't have the cash/resources to do my own research.
Thanks
Dustin-Dustin
17' Action Marine - Merc power
01-22-2010, 07:37 PM #2
I would start with a 27 srx. Someone was just selling one worked by DAH.
Chet Olson
01-22-2010, 07:52 PM #3
You are about 5 hrs from me. This spring you could tow over and try several props. I loved the chopper on my Streams.
RockTeam Junk
01-22-2010, 07:52 PM #4
01-22-2010, 08:18 PM #5
You don't think the Choppers would have too much bow lift and want to blow over with a heavy V6 out back? SRX's are similar to Choppers as they lift the bow correct?
-Dustin
01-22-2010, 08:22 PM #6
01-22-2010, 08:24 PM #7
It's a good thing this hull came with dual cable steering and a hot foot lol.
-Dustin
01-22-2010, 08:26 PM #8
01-23-2010, 12:39 AM #9Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
QH you will want more than one prop. They hold their value so don't worry about getting rid of one if it doesn't work for you.
01-23-2010, 12:57 AM #10
Your first wheel should be a 27srx, or 26-28 chopper, mazco, spinelli ect...
Then SHow your A$$ up at an event with a smile and I would bet youll be able to try a few...2006 Action Marine Comp
1980 Ventrua 2
01-23-2010, 10:21 AM #11
Riverman - Thanks, I just didn't want to buy one that sat on a shelf and loose too much coin.
Laker - As soon as the boat is done and the weather turns you bet your last dollar I'll be up there when I know where one is at!-Dustin
01-24-2010, 08:43 AM #12
If I had your boat and could buy only one prop it would be a 27 SRX built by DAH for a Stream. They are easily bought here in S&F for under $400. It will carry a load accelerate well. You can even pull the kids on a tube with it. A 27 Trophy would be my second choice and a stock chopper third. The Trophy is an awesome all around prop.
01-24-2010, 12:12 PM #13
Thanks Wizard, it seems the SRX is the one that keeps coming up in each post. I'll do some searching for one.
I did forget to mention I have a 6" jackplate on the boat as well, not sure if it makes a difference in the suggestions, I just forgot to mention that.-Dustin
01-30-2010, 12:30 PM #14
A big ear chopper with an offshore cut works well.
02-02-2010, 09:12 PM #15
Sounds good, I'll keep my eyes peeled.
-Dustin
