Results 31 to 45 of 54
Thread: venturi effect, nozzle design
01-15-2010, 01:50 PM #315000 RPM
- May 2009
- FL
- 345
I think fire fighting nozzle would be the ticket it can go i think from dumping large amount of water to a fine spray. you wouldnt nedd it to go to the fine spray but just to the highest velocity
01-15-2010, 07:14 PM #32
unfortunately a variable orifice nozzle would reqiure alot of moving parts, and would be subject to alot of debris possibly fouling the function of it. Not to dishearten you, but you would severly limit your target market if you fail to address this problem. The top river race guys (like the baked bean can shown above) would be all over it like white on rice, but if the part was prone to fail everytime you run aground then it would be left on the shelf.
When I read venturi, the tool used by Airbus to fill their emergency escape slides came to mind, where a high pressure stream is thrust through the centre, then due to the venturi effect more air is dragged through the nozzle further increasing thrust.
The SR71 Blackbird had a cone in the inlet to vary the amount of air available to the engines at sub-sonic low altitude speeds versus super-sonic high altitude speeds...
Something else to think about...
01-15-2010, 07:54 PM #33
thanks oldsleekolds for the rr link, i read all 25 pages and was suprised that they were saying large nozzle for top speed small nazzle for hole shot. i wonder what the ftnozzle people feel about that? is it correct?
01-15-2010, 11:35 PM #34
There are at least a couple guys that have been there and done that....Duane being one of them. I certainly would have no reason to doubt what they are saying.
I think the guys running light boats and more that 500 hp are going to see the most gain with a nozzle that can be adjusted on the fly. The rest of us are probably not going to gain a lot no matter which nozzle insert.
I've been tinkering and reading for a long time. I have a machine shop so I can make whatever I want. If you wonder why jet boats are not efficient consider what needs to happen to make it go.
Water must be made to go up into the pump through a rectangular hole
The water is forced through a round hole that has an impeller in it
The impeller forces the water through the bowl which is kind of like a funnel
The water leaves the bowl and goes through a steering nozzle and/or diverter
Nothing new here....right? Think about how many gallons per minute your pump will put out at WOT. Now think about the weight of that water. That's what makes the boat go.
Now think about the weight of the water going through the pump PER SECOND. Now think about how much power it is using to change the direction of the water as it moves through the pump.....from rectangular to round......to smaller round (bowl).....to still smaller round (nozzle).
The only thing I can think of that could make a significant improvement in efficiency is to aerate the water going through the pump. Introduce air bubbles via venturi at the point where the water leaves the impeller if possible. Everything downstream of the impeller would need to be redesigned of course. The closer to the impeller the air enters, the greater the gain. The objective is to get a lot more water through the pump with the same hp. The boat will then go a lot faster with the same hp.
old
01-16-2010, 12:17 PM #35Member
- Nov 2009
- whitehorse yukon
- 41
01-16-2010, 01:23 PM #36
i guess with that kind of funding you will also work on a variable intake to work in conjunction with your variable nozzle and variable impeller
01-16-2010, 01:28 PM #375000 RPM
- Oct 2009
- Shell Knob MO 65747
- 141
I'm with Ya on that one. If I win first, I'll already be on it. I love this S***!
Hmmmm, the board won't let me spell out Stuff??
Duane HTP
01-16-2010, 01:37 PM #38
might as well throw in a 2 speed transmission also
01-16-2010, 03:13 PM #39Member
- Nov 2009
- whitehorse yukon
- 41
the sky will be the limit boys!!!then,,,, we will hafta go testing in a tropical enviroment! and while were at it,,we could also???,,,,
01-16-2010, 09:59 PM #40
go to a all u can eat buffet? ha ha
01-17-2010, 12:01 AM #41
Back in the day, they ran chokes in the nozzle, on the launch.... The chokes were then spit out for the big end. Then they figured that was kinda exspensive, and settled on a selected insert.
UMPBA 926 Gas Jet
01-17-2010, 11:31 AM #425000 RPM
- Oct 2009
- 141
I remember those days. We used to do it. I was always afraid of hitting a v-drive behind me with one of the released inserts. Ha Ha, Just having fun.
01-17-2010, 04:54 PM #435000 RPM
- May 2009
- FL
- 345
now i am totaly confused i thought large was hole shot and small top end more velocity high speed ,volume hole shot
01-17-2010, 05:01 PM #445000 RPM
- Oct 2009
- 141
It is confusing. Lighter boats with very high HP react opposite of heavier boats with lower HP. There's a crossover in the equation somewhere. Your job is to find the right one for your boat and Yes, it can be confusing. It's not like going to a chart and reading which nozzle your boat should use.
01-17-2010, 05:09 PM #455000 RPM
- May 2009
- FL
- 345
Ok i started to think about this . would it be best to have a larger pump to move more water and then you could have a larger nozzle to keep the back pressure down but just large enough to get the best water velocity out the nozzle
