Results 1 to 6 of 6
    Aug 2003
    Onset, MA
    1996 Yamaha 200 Mids Interchangable with Older Yamaha Powerheads
    Anyone know if and older 1988 2.6L Yamaha 225 Excel powerhead will bolt up to a 1996 200 Midsection. I came across a pair of sinker motors and a pair of excels with busted shift shafts (and no lower units) . . . just wondering if I can make a working set for a fishing boat project. Otherwise I'm gonna go twin Merc 135 2.0L's. Keeping this project on the cheap.
    Nov 2004
    south alabama
    as long as the newer ones are 2.6s they should work
    hold on and hope for the best
    Sep 2006
    Key Largo, Fl
    all the 90 degree blocks will bolt in the same place
    May 2020
    florida
    Can the electrical system from a 1989 be used on a 1990 if they are also both 2.6 motors and both 2 stroke, was wondering because I have a good 1990 225 and need the harness and electrical and I found a 1989 with everything but it has a hole in the block
    Gothenburg, Sweden
    Yes. I think the 1989 and 1990 225 were identical.
    May 2020
    florida
    Quote Originally Posted by Markus View Post
    The only main difference I think is the charging system went to 35 amps in 1990 the stator and flywheel are completely different part numbers
    But I can transfer all the 1989 good parts to my 1990 which has missing parts and end up with a complete motor with the oil tank and control module I am thinking
    I am new to Yamaha interchange but for OMC I am very experienced
