Results 1 to 9 of 9
Thread: Coolant Cold Leak Explorer
12-13-2009, 10:48 PM #1
OK, I'm bout at wits end.... Got a 95 Exploder, 4.0 pushrod motor. Have had coolant leak when it got cold out last winter and now it's back. Thought I had it fixed.
Replaced parts including radiator & cap, t-stat and lower hose & clamps. Seems like everytime it's appears to be the lower hose or radiator tank on LH side. Tonight I pulled the lower hose again and cleaned just a little bit of corrosion off the water pump.
I'll post pics if it comes back tomorrow, I'm sure it probably will. Any ideas????
NickSunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
12-27-2009, 05:58 PM #25000 RPM
- Jul 2005
- Poynette,Wi
- 112
Its
the timing chain cover (I bet!)
12-27-2009, 06:23 PM #3Screaming And Flying!
- Miami,Fl
- 6,989
- 128
- 80
- 1262
- 366
Any play in the water pump? Wobble maybe? Rick
12-27-2009, 10:45 PM #4
99% sure it's the plastic tank meeting the aluminum core. It seems to push past the gasket when the system starts building heat/pressure. Once the radiator builds some heat and expands the leak stops. Kinda pisses me off since I just put a radiator in it last year. Gonna just take the lower seal off the cap during winter and put it back on during summer. Anyone wanna buy an Explorer? Bought an Excursion this past week....
12-28-2009, 08:57 AM #5
You are probably correct. What brand radiator did you install? We have had our local NAPA change vendors just for this reason. High warranty failure rate on thank to core seal leaks. I have had several that did not make it a year.
12-28-2009, 09:00 AM #6
It came from CarQuest. I think it's a Modine but not sure. It didn't make it a year.....
01-03-2010, 10:13 PM #7
rad core leaks
Make sure yu have a good motor to frame ground strap , bad ground could cause electrolysis of alluminuuuummmm core and will not last but about a yr
MITCH HARDEE 803-974-0350 --- 95 CUSTOM BASS RR STV/300drag-- 2004 STV RR/300drag---14ft fastcraft/12in/ssm--F.I. 3cyl -whittled from 300-drag --2008 FTPB STV RR( POC FACTORY BUYBACK) IRATATE A LIBERail --missspell som'um--SPONSORS --THOROUGHBREDS INC.
01-04-2010, 01:14 PM #8
I just removed the seal that pressurizes the rad. Not the one on the very top but the one that seals down in the neck. Don't really need pressure on it during winter. Will put a different cap on it in the summer.
Thanks for the help and advice guys!!!
02-27-2010, 12:47 PM #9
Most radiators are lifetime warranty, check your receipt and just get another one. This happened to me, bought mine from Napa and it dripped out of the side tank only when cold! Tech at local Ford dealer.
