Results 1 to 7 of 7
Thread: gale banks twin turbo 460
11-29-2009, 08:38 PM #1New Member
- Nov 2009
- Wamego Kansas
Does anyone have any tunning info on the late 70's gale banks twin turbo draw though systems. I have a kit with the intercooler and turbos manifold for the carbs and all the pluming. Just lloking for timing and spark plugs and the gap. Anyone else running this setup on a big block Thanks Kevin
11-29-2009, 08:50 PM #25000 RPM
- Jun 2009
- DFW
- 183
Banks is still around. Why not call them.
www.bankspower.com
11-29-2009, 10:38 PM #3New Member
- Nov 2009
- Wamego Kansas
12-01-2009, 12:55 AM #4
"infomaniac" on PB forum can help with answers
UMPBA 926 Gas Jet
12-01-2009, 06:22 PM #5New Member
- Oct 2009
- Toronto
I have a Banks twin turbo 468 BBC. I didn't build it so I can't give any tuning advice, but I really like the set-up. I am disappointed to hear that Banks would not help you out when you called for advice.
12-20-2009, 05:08 PM #65000 RPM
- Sep 2008
- Montana
- 170
timing, pull out a few degrees, run the boat on 110 octane for safety when you're tuning. start your gap at .038 or so, maybe a little bigger. depending on your ignition you can open them up some more. also, a heat range colder (low boost applications) than stock will help with detonation. just general turbo tuning.
Boost free, for now...
Old Ladies Driving Slowly, Making Others Behind Infuriatingly Late Everyday
12-20-2009, 05:14 PM #75000 RPM
- Sep 2008
- Montana
- 170
oh yea, raise the boost in increments. start very low, like 3 psi. between runs, make sure your heads aren't being lifted. use a wideband. tuning 101...
at given boost level, run baseline.
if the AFR is rich, and there is no knock, add timing. if it leans out the next run with the timing, you're still in good shape. add a bit more fuel, run it again. if it continues to lean out when adding timing, you can repeat the process. when adding timing does NOT lean out the mixture any longer, pull two degrees and you're basically good to go.
obviously, if your baseline run is lean, you can add fuel before messing with the timing.
adjusting fuel, i can't help you with, i have no clue what you'd do with a set of carbs, my tuning background is small displacement, bigger boost, EFI. anyway, best of luck, and if it's over your head, find an expert.Boost free, for now...
