Results 1 to 5 of 5
Thread: 460 Ford back fire?
11-15-2009, 05:16 AM #1
460 Ford back fire?
The motor runs fine at WOT, but as soon as I back off the throttle there is a misfire. Only at Half open throttle.
11-15-2009, 05:35 AM #25000 RPM
- Apr 2009
- Orlando.FL
- 122
Sounds like cam related
11-15-2009, 05:38 AM #3
Do you mean cam timing? I know it is a Comp Cam stage 1. Can it be carb related as well?
11-16-2009, 06:00 AM #45000 RPM
- Apr 2009
- Orlando.FL
- 122
Carbs don't backfire the workings of the engine sound back thru the carb. EX a pop thru the carb usually notes a Intake malfuntion, cam, valves, etc.
11-16-2009, 06:48 AM #5
Thanks - Will check cam timing
