Results 1 to 3 of 3
11-03-2009, 10:49 AM #15000 RPM
- Apr 2004
- Houston,TX
- 167
2008 Mercury 150 DFI 14pin connector question
I dont have a key switch for this motor yet but was wondering if anyone knew the pin numbers for starting and stopping a 2008 Merc. 150 dfi with a 14pin connector?
11-04-2009, 08:33 PM #2
You can jump the A and the C pins together. This will power everything up. Then use a starter button on the solenoid.
Life Begins At 100 MPH
11-04-2009, 08:43 PM #3
only issue is shut down... it will fire that way but not shut down properly... you can damage injectors by cutting power to the boost fuel pump and shutting things off that way... personally i would wait until you have a key...
