Results 1 to 15 of 24
Thread: Paint/Body Guys....
10-28-2009, 04:27 PM #1
Paint/Body Guys....
whats the secret to keeping from gumming up D.A. paper on your first pass over freshly cured mud???
Paying almost a buck a pc for 40 grit 3M and hate round canning it after 30 seconds use.
Thanks, GaryI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
10-28-2009, 04:47 PM #2
let it cure longer, also, a heat lamp helps.
10-28-2009, 04:51 PM #3
Mud
I feel your pain I walk around the shop all day a look at paper laying on the floor. Your mud is really not dry or not enough hardner. I realize its easier to knock down at that point so I take my air line and try to blow the mud away as I sand, it seems to help. I also have a wirebrush that attaches to my airline that cleans the mud out of the paper but you can use a regular wirebrush. You kinda just chalk it up to the cost of repair. That is what most people don't get when I write an estimate, the sand paper is .75-$1.25 a sheet,tach cloth $1.00, plastic I cover you car with $3.00... Its all small amounts but adds up by the end of the job and makes it tough to work for anyone other than the insurance companies. I don't know if that answers or helps but that my .02.
Good Luck Jerry
10-28-2009, 04:58 PM #4> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
10-28-2009, 06:40 PM #5
Been years since I used one but perhaps if you start with a cheese grater style body file and knock the top off it won't gum as much. It seems like that top layer is the worst. I remember buying one many years ago for under 20 bucks.
10-28-2009, 06:46 PM #6
Take a paint stick, and smack the paper on the bottom of the DA sander a few times...it will usually knock most of the gummed up stuff off of the paper so you can keep using it
Ian
...boatless for now.
10-28-2009, 06:57 PM #75000 RPM
- Jan 2005
- Gramercy, Louisiana
- 203
cake
and also a good quality sand paper.... i like the sunmight,or the 3m....
10-28-2009, 07:31 PM #8
Get some of the ultra lite filler. It sets up quick, sands easy and dosen't clog the paper.
Bruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
10-28-2009, 07:39 PM #9Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,737
- 102
- 115
- 1556
- 514
God, Country, and Fast Boats
10-28-2009, 07:48 PM #10
Well............
I mix it hot enough that it only lasts a couple of mins on the board but I can come out and sand it 2 days later and still plug up paper. Mud is only a couple mnths old and been in the garage entire time.
I like the wire brush idea. Thaty sounds killer and will try it tomorrow.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
10-28-2009, 07:52 PM #11Screaming And Flying!
- Mar 2003
- 7,737
- 102
- 115
- 1556
- 514
The paper is not damp or holding any humidity is it ?
ChrisGod, Country, and Fast Boats
10-28-2009, 07:54 PM #12Bruster's Mercury solid motor mounts, details here:
10-28-2009, 08:31 PM #135000 RPM
- Oct 2007
- 116
Hope you are not using bondo on a boat......
Fiberglass reinforced polyester/vynilester resin, gel coat, epoxy, or epoxy sealer. All of which are even more time consuming to tool down.
That should stir things up_but my 2 clams......
10-29-2009, 07:20 AM #14
Already using ....
a good filler.
And yes I'm using bondo on a boat Using it as a fairing material only and above water line. Will be covered by epoxy sealer before getting 2 part paint.
Have done it this way for yrs and yrs with no issues at all.
BTW, I'm also using "car" paint on my boatI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
10-29-2009, 01:37 PM #15
Rage from Evercoat.
http://www.evercoat.com/productDetail.aspx?pID=32
