Results 46 to 60 of 78
Thread: Project Jet boats what is your's
09-18-2009, 10:13 AM #465000 RPM
- Mar 2009
- Tulsa,Ok
- 573
Interlux makes a high build fiberglass primer ( InterFill?) that I was told will fill spider cracks and not shrink, since my 58' Biesmeyer has a ton of them, fix the major by the V method when it's smooth I will try it
09-19-2009, 09:19 AM #47
Nothing fills in spider cracks, they come back unless ground out and glassed over again. check the other side, to see if there is a stress point on the inside of hull, that needs to be adressed first.
just finished my two year resto on my Southwind Tunnel Dragster
it all started here... http://www.banderlog.com/phpBB2/viewtopic.php?t=5311
UMPBA 926 Gas Jet
09-19-2009, 09:53 PM #48
Southwind Boats
(N i c e)
This Southwind belongs to my buddy Jr Jetter in NC.
http://Last edited by WICKEDRISTER; 09-28-2009 at 02:04 PM.
Southern Hotboater
09-20-2009, 12:52 PM #4979 Southwind Tunnel Dragster 540ci BBC
UMPBA 926 Gas Jet
10-02-2009, 09:56 PM #50
Bought this one since mine is still in Florida in pieces.. 77 Carlson CVX20 468 Full Roller Chevy, JE pump worked, Stainless A.. Blah Blah.. Needs a new paint job.. Winter project..
10-08-2009, 02:20 PM #51
This will more likely end up being a 2 year project than a winter project. I picked up this 71 18ft Cheetah for $350 off craigslist. Came with a BBC top mount starter and bellhousing, Berkley 12JC-A pump, tilt trailer w/ hyd. brakes and most of the basic necessities. Plans are to replace all the soft wood under the dash on the sides, pull the carpet and replace the floor, and learn how to fabricate an interior. I want two buckets up front with a wrap around bench in the rear. The hull is solid and not bowed on the trailer and the quarter stringers look great. Motor will be a mild 402 BBC w/oval port heads, single plane intake and through-transom exhaust. I'd also like to put a ski-deck on the transom.
I am still looking for advice on cam/valvetrain, carb and oil setup selections. Looking for about 60-65mph.
Boat and I are located in SE, MI.
9/29/09: The day I bought it.
And here it is two hours later after a good wash and shoveling out about 20lbs worth of compost.
The hull looks like it will buff out back to a real shine without a problem. The upper part is going to need some touch-ups and a new clear coat. I really like the metal flake so I may just respray it with a blue tinted clear to bring it back to it's former glory. Oh and the windshield is cracked, and I bet it's a fat chance in hell I can find a replacement.
I look forward to reading and learning a lot about vintage jet boats. I've wanted one for years and finally the stars aligned to bring me this.
-Dave
P.S. This is also my intro post. HI ALL!
10-08-2009, 05:52 PM #52
Courtesy of Hi-tech performance HTP they have a supplier of the bubble windshields. I have a friend that bought one for his Taylor SS fit perfect.
HTP
We have had many people ask where they could buy a windshield for the Taylor SS Boats. Below is the Information.
Middy Plastic Products Inc
9320 151st Avenue Northeast, Redmond, WA 98052
(425) 883-460079 Southwind Tunnel Dragster 540ci BBC
UMPBA 926 Gas Jet
10-15-2009, 09:06 PM #53Member
- Jun 2006
- Plainville Ct
- 32
Maveric , you still have that bowl?
would you ship to Ct
10-16-2009, 07:46 PM #545000 RPM
- May 2009
- FL
- 345
yes i have it
10-16-2009, 07:54 PM #55Member
- Jun 2006
- Plainville Ct
- 32
will you ship to Ct , how much ?
does it have any cracks ?
10-18-2009, 04:45 AM #565000 RPM
- May 2009
- FL
- 345
ya i will ship it $75 pluse shiping and i dint see any crack but I will give it the once over again. the bowl came off a jf pump just so you know and can make sure it will work for you ok
10-18-2009, 07:54 AM #57Member
- Jun 2006
- Plainville Ct
- 32
Mine is a JC will the Jf work ?
10-18-2009, 07:22 PM #585000 RPM
- May 2009
- FL
- 345
it will fit but dosnt have the provission for the O ring on the out side you could silicone it though to seal it to the transom cover
10-18-2009, 07:38 PM #59
99% of the 0-ring installs leak anyway, most all are siliconed anyway.
UMPBA 926 Gas Jet
10-19-2009, 08:17 AM #60Member
- Jun 2006
- Plainville Ct
- 32
My Boat is a Sanger and does not use the large trim on the transom , It uses the Sanger Trim Ring .
I will look up the JF pump to see .
