Results 1 to 15 of 21
Thread: Mercury 250 EFI prop
08-04-2009, 08:14 AM #1Junior Member
- Mar 2009
- Miami, FL
I am running a 2000 250 efi on a 93 22 concept with a 23 chopper( I believe if not it's a 22) which it takes me a while to get the boat on a plane especially when I have a couple of people on it, it even takes longer to plane I have to put everyone in the front of the boat to plane, the engine is boarded out with bigger pistons. So what should b a good prop for off the whole and top speed I was told my chopper was for top speed. So what's a good prop for my setup.
08-04-2009, 09:36 AM #2
A 22-24 bravo with 1" vent holes would be a good start
Shaun
786.229.5801
24 Skater twin 15" STR 3.2 Liter EFIs (sold)
28 Skater Twin 300x (sold)
27 Concept Twin Verado
30 Skater (under construction)
STR X-Act Brackets The Only way to GO FAST PRECISELY
08-04-2009, 09:39 AM #3
Hey
Trophy plus best all around
08-04-2009, 09:58 AM #4Junior Member
- Mar 2009
- Miami, FL
What would b a price on one of those props
08-04-2009, 10:01 AM #5
Hey
If your talking used trophys anywhere between 200 and 300. New there 4 and change.
08-04-2009, 10:14 AM #6
Not to add any more confusion to this thread, but My 24 Pantera Hull isnt THAT far off from your 22 concept. I run a Solid Hub old school 23 mirage, best prop I have. I also have a 21 Mirage Plus, not a bad prop, but the standard mirage handles better. I run a 225 carb motor, and have NO Problem getting on plane, top speed 55-59 depending on weight..
08-04-2009, 11:33 AM #7Junior Member
- Mar 2009
- Miami, FL
well I got mine up to 69 on a gps but I think I can hit low 70's but it's just getting on a plane is what I'm worried about because it just goes to high in rpm for me to get on a plane and I'm guessing that can cause some damage to the engine doing that everytime I wanna get the boat on a plane especially when I got 4 or 5 people on the boat
08-04-2009, 11:49 AM #8
What RPM are you turning at 69MPH??
08-04-2009, 12:00 PM #9Junior Member
- Mar 2009
- Miami, FL
5400-5500 rpm
08-04-2009, 02:42 PM #10
Thats strange, cuz I run a 23, and can only get 58 at around 5200 RPM, I doubt 300RPM gets you 11MPH, either I have major slip, or you have near 0% slip at WOT, but tons down low(prop cavitaion on takeoff)?? Cant tell without the prop calc. right now. Is that 69 GPS MPH, or speedometer??
08-04-2009, 05:18 PM #11Junior Member
- Mar 2009
- Miami, FL
That's gps mph well I'm kinda new at this but I know I was reading those numbers right when I got those numbers but also my engine is boarded out And bigger pistons would that have a difference
08-04-2009, 08:14 PM #12
May have a difference, do you have a weight on your boat, I will run the prop calc, and see what you need.
08-04-2009, 08:49 PM #13Junior Member
- Mar 2009
- Miami, FL
Well on the website it say 2300 without engine so add another couple of hundred pounds for the engine
08-04-2009, 11:34 PM #14
Might try a 23 mirage plus.JMO
08-05-2009, 07:03 AM #15
Assuming I got your gear ratio close(1.67), I suppose it is possible, but comes out to 3% prop slip which is unheard of, I wouldnt change a thing. You could get a prop to get you on plane better( I would start with the 23 Mirage or mirage plus as mentioned above), but you WILL suffer on top end.
