Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 74
  1. #31
    Aug 2018
    Ct.
    Progression 24 300 xs
    Thanks all. Any more thoughts are welcomeClick image for larger version.
ID:	432607Click image for larger version.
  2. Likes moatorbotin liked this post
  3. #32
    Apr 2017
    Pomona ny
    Quote Originally Posted by ecamiel@snet.net View Post
    Is the light bow as much of an issue with the 24 as with the 22?
    what kind of speeds and conditions caused the boat to get air born and do a 180? Was that a barrel roll or a back flip?
    Never rode in a 24 but all progressions are pretty much known to be light in the bow. I've never experienced it hooking before but close to 90° a few times. Imo an offhore mid is a must with these hulls to keep the drive from kicking out. You'll be alright just get a season or two under your belt
  4. #33
    Aug 2018
    Ct.
    What prop? RPM? Cruising speed at 3000 and 4000 RPM? Any other set up information?
    I have the same boat and motor, 2006.
    Thanks
    Eric
  5. #34
    Apr 2017
    Pomona ny
    Beautiful rig always loved the color combo on it. That setup should be able to break 80 np
  6. #35
    Feb 2003
    Rochester, NY
    Quote Originally Posted by marks86 View Post
    I had 380 k planes on mine, I remember talking to Kevin about the boat and I’ll never forget what he said to me. Learn how to drive the boat with the tabs down. Makes sense
    Yea, I'd say he's mostly right there. I might recommend learning how to drive with them either level with the bottom or just slightly down. That's pretty much where I run mine all the time. The only time I pull them all the way up is when I want to make the jump to ludicrous speed.
    BTW: I've driven an awful lot of boats in my 63 years and I work at a marina. Based on that experience, I'd say 380 K-Planes are pretty much over kill for a 22' boat. I've been out in some pretty hellacious water in mine and never felt I needed anything bigger than my 12"x12" tabs. For instance, note that my tabs aren't even half way down in this snot:
    [IMG][/IMG]
    1992 Progression 22
    Mercury Racing 250R
  7. #36
    Aug 2018
    MI
    I never owned a 22, but I had a 24 with cabin similar to the blue and white boat on the web site. I will say that when running 75-85 my 24 felt more flighty than my 2006 hydrostream vegas. Cross winds pushed it around a lot more, probably because it is very light for its size and allowed the wind to blow it around more than the similar (though lighter) weight vegas which was much more sleek and had less surface area.
    I had a 300x and saw over 80 with mine fairly consistent, but 78-80 any day.
    Only once did my 24 stand up on me and make me think my day was over. I was running hard, 75-80ish and hit a hole in the water I never saw, otherwise with conservative trim and a nutral tab (380 k planes on mine) it would run through most anything.
  8. #37
    Nov 2007
    Had a 22 then moved up to 27,great all around boat Click image for larger version.
ID:	432619 best speed 110 so far
    27 Progression IO 22 Progression 300xs sold http://youtu.be/_K8boEfKrx4
  9. #38
    Nov 2007
    22 had 300xs best of 95,low 90s all day, as stated need seat time but boat will run through anything![ATTACH=CONFIG]432620
  10. Likes bouyhead liked this post
  11. #39
    Jan 2017
    Albany NY
    Quote Originally Posted by goneby View Post
    Where is this boat now?
  12. #40
    Nov 2007
    Runs out of Wantagh
  13. #41
    Nov 2007
    Has a 250xs now
  14. #42
    Jan 2017
    Albany NY
    Has a 250xs now
    why do such a thing
  15. #43
    Nov 2007
    He's just wants to get out and enjoy,not looking for top speed,hes out all the time, loves the boat,P,S you wont find a better built boat than a Progression
  16. Likes bouyhead liked this post
  17. #44
    Aug 2018
    Ct.
    What prop and set up were you using to get 80 +? Was that prop a reasonable prop for multi use, load and acceleration or a top speed only prop?
    Running a little tab seems like a reasonable way to start out and learn the boat.
  18. #45
    Aug 2018
    Ct.
