Results 16 to 30 of 74
Thread: Progression boats???
08-04-2009, 02:24 PM #166000 RPM
- Jan 2004
- MD
- 1,008
08-04-2009, 03:54 PM #17
08-04-2009, 07:17 PM #18
08-05-2009, 12:39 AM #19
1986 23' Ghost- RIP
1986 28' Ghost- SOLD
03-02-2019, 09:08 AM #20Member
- Aug 2018
- Ct.
- 55
- 13
I just bought a 24 LD with a 300 XS. Any information or advice you could give me will be greatly appreciated. Prop? set up? Handling? Motor issues?
I'm a total newbe to this motor and boat.
Thanks
Eric
03-02-2019, 04:00 PM #21
First of all, welcome to the Progression club! You've purchased a great boat and motor and it should give you many, many years of faithful service. A vacuum bagged (not all of them were) 24LD with a healthy 300 XS should be about a 74 MPH (on GPS) boat. I think you'll find that getting that kind of speed out of it - unless you've driven a pad bottom hull before - will be somewhat elusive. Before you go for it, let's talk about some preparation.
The first thing you want to do it "nut and bolt" the whole boat - particularly the motor mounts and steering - to make sure everything is properly torqued and has no play or wear in it. And speaking of steering, you should have full hydraulic steering with that kind of power. If you don't feel comfortable doing this your self, hire a mechanic you can trust to do it for you.
After you're sure the boat is ready, make sure you're ready. Sit in the boat either on dry land or in the water at the dock. Familiarize yourself with the operation of all controls - particularly steering, throttle, tabs and trim. (And jack plate if it has a powered one.) When you get the boat up anywhere near top speed, things happen in a hurry and simply dumping the throttle when things get uncomfortable is usually the wrong thing to do. So knowing what control has what effect and which way you move it to get that effect needs to become "muscle memory."
Finally, when you're ready to actually launch and drive the boat, start out slowly and only work yourself up to speed as you feel comfortable. Having somebody who's driven a boat like yours out with you for the first few trips can be invaluable. Try different speed, trim, trim tab and jack plate height settings to see both how they work and what effect they have on the handling of the boat. Almost as important as what settings have desirable effects on the boat is learning what settings the boat doesn't like.
If I were a betting man, I'd say that you'll be able to get the boat comfortably up to the mid to upper 60's relatively easily. It's the last few MPH that require a steady hand and lots of experience. Don't get greedy here. I always say that my grandmother could drive my 22 Progression up to about 60-65 MPH. Getting it to its top speed of 77 MPH takes brass balls though. I also say that my P22 is "like driving a Formula One car on the street." It's not for everyone, but once you learn how to make her dance, there's absolutely nothing like it!
Have fun and be safe!
Tom1992 Progression 22
Mercury Racing 250R
ecamiel@snet.net thanked for this postJBS liked this post
03-02-2019, 05:18 PM #22Member
- Aug 2018
- Ct.
- 55
- 13
Thanks, All very good advice.
I’ve raced cars and motorcycles. The approach seems to be the same.
During the sea trial we saw 72 to 73 With 2 people and half a tank of fuel, light chop.
I drove the boat comfortably to the low 60s but felt I had my hands full beyond that. I happily backed off.
The previous owner Who is an ex boat racer and Kevin from progression have both offered to give me lessons. I will definitely take them up on that
If dumping the throttle is not the thing to do, do you just back off slowly when things get scary?
Thanks Eric
03-02-2019, 06:16 PM #23
Most high performance boats don't like it when you abruptly chop the throttle(s) - particularly if you're trimmed up. When I get into trouble on mine, I've found that trimming down immediately (I have an In Control Foot Trim pedal) combined with backing off gently on the throttle is a far better way to go. I know some Progression 22's will take a pretty sharp turn if you chop the throttle.
1992 Progression 22
Mercury Racing 250R
03-03-2019, 06:35 PM #245000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Progressions tend to be flighty in the bow. Before you learn the handling characteristics be very careful.
moatorbotin liked this post
03-03-2019, 07:56 PM #255000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
this is true, first month I had my 22 I shot the bow straight up and did a 180 in the air. I didn't realize how light the boat really was until I was in mid air thinking to myself " Im a large kite at this moment" not fun that's for sure.
I learned with that boat neutral trim was key to success with a 22 progression
03-03-2019, 08:15 PM #265000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Same thing happened to me plenty of times. I must say it's the one flaw I see with these hulls. It wasn't til I sat passenger while an experienced driver took the wheel I truly saw and learned what these hulls are capable of. Blipping the throttle before hitting a wake or an unfamiliar wave does wonders. Getting the proper attitude right before entry goes a far way. I'll say one thing taking these hulls to the limit will definitely get your adrenaline flowing.
03-03-2019, 10:04 PM #27Member
- Aug 2018
- Ct.
- 55
- 13
Is the light bow as much of an issue with the 24 as with the 22?
what kind of speeds and conditions caused the boat to get air born and do a 180? Was that a barrel roll or a back flip?
03-04-2019, 06:58 AM #28
Trim tabs make all the difference in the world here. (Along with an experienced driver.) Mine got really light in the bow once before I added 12"x12" tabs back in 1996. I haven't had a problem since. Like any true high performance boat, you need an experienced driver to get the most out of it. That said, I'm reminded of the wise old saying: "Wisdom comes from experience. Experience comes from messing up."
1992 Progression 22
Mercury Racing 250R
03-04-2019, 07:01 AM #29
The 24 is a heavier boat than the 22, but the overall balance is similar. Relatively speaking though, the 24 is harder to stand on its transom. You can stand a 22 up at about 55 MPH in a stiff head wind. With the 24 in the same conditions, I'd say you'd have to be going at least 65-70 MPH.
1992 Progression 22
Mercury Racing 250R
03-04-2019, 07:12 AM #305000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
I had 380 k planes on mine, I remember talking to Kevin about the boat and I’ll never forget what he said to me. Learn how to drive the boat with the tabs down. Makes sense
