Results 1 to 6 of 6
    Jul 2009
    Wallaceburg, Canada
    Will my 12 JE berkley pump accept a Jetovator
    Hey guys in new the the jetboat scene i purchased mine a year ago and have had great fun with it so far but I was looking on getting a jetovator for it because my manual trim tab is a pain and i love the roostertail option but Ive read too many things to tell if I can even get one to fit my pump without expert advice and rom the other threads ive read this is the site to check.. Im running a 1979 Wreidt with a 502 chev bb and a 12 JE berkley Pump not shure on the impeller i havent had the bowl off yet and i will post pictures soon Im going to take some new ones this weekend, also I was wondering if it will accept a jetovator without changing pumps roughly how much and hwere i may get one thanks a bunch guys
    Brad
    Feb 2008
    Joliet IL
    Yes, Place Diverter makes them, they are more expensive for the JE than the JG. You make be able to find a used JF with factory trim (jetovator).Should interchange with the JE. Try looking on performanceboats.com in the spam section or try Arsmarine.com
    Mar 2009
    TENN
    yes place diverter makes one that is a direct bolt on and is a great piece, they make the standard and a ftn that allows you to change the bushing in the end to the diameter that best suits your boat, available in manual or hyd trim, in my opinion stay away from a used berkeley f as it is a nightmare to remount and is an obsolete piece. pm me if you need more info as i usually have the e units in stock.
    for some reason when bigA answers i feel like no other replies are needed
    Merritt Island FL
    my je pump with jg bowl and diverter.
    Oct 2003
    S.W.VIRGINIA USA
    Quote Originally Posted by waterslinger View Post
    JG split bowl, Droop Snoot and hydraulic Place Diverter Can you post a pic of the other side of the pump, would like to see how the steering and forward reverse cables are connected with that big droop.
    Southern Hotboater
