Results 1 to 5 of 5
Thread: mounting bolts
07-29-2009, 11:25 AM #1
mounting bolts
i am mounting a 175 merc on a hydraulic jack plate. i need to pick up a set of bolts before i head to cottage. what size and length and what grade of stainless steel to buy?
07-29-2009, 11:33 AM #2
motor to jack plate or jack to transom....
2.5" long 1/2" fine thread 304 stainless is what most jack plate mfg include for motor to jack
if you can get 308 or 316 stainless it would be stronger yet, 18-8 is comparable to grade 5 and is minimum required but not recommended imo..
personally id go to a mercury dealer and get a proper set of bolts in the length you need and that way you also get the brass nylock nuts to go with..
07-29-2009, 11:47 AM #3
If you use stainless nuts, put a bit of wax on the threads to prevent seizing.
An old candle, spray furniture wax, turtle wax, anything works.)
hope it helps
JohnTo fish or not to fish? What a STUPID question.
07-30-2009, 06:30 PM #4
07-30-2009, 10:55 PM #5
Also try and get Nyloc nuts so you can be fairly sure they won't loosen on you!
