Results 1 to 5 of 5
Thread: Aluminum for floor????
07-26-2009, 08:34 PM #1New Member
- Jul 2009
- michigan
Hi.I am not sure if this is right spot for this question or if there is a right spot for it I am currently doing a restro on a 1981 Glastron SSV151 and I am currious as to weather or not I can use alum inplace of wood for the flooring? I would like the wiehgt savings and no rot qualities but am nervouse of it perminatly bending if I hit a big wake and the boat flex.Any advice apreciated..Brian
07-27-2009, 09:30 AM #2
Besides being hot as a firecracker in the summer heat, by the time you get aluminum plate thick enough to withstand the rigors of the hull's beatings, marine plywood may be the ticket, far cheaper too.. easier to work with and it will flex when and where needed.
jus' my opinion tho'.............RBRuss Benton
Allison XB-2003 w/JSRE Pro Max
Allison XR-2001 w/260 +
07-27-2009, 12:01 PM #3
I believe Fir plywood uses the same glue as marine plywood, and is alot cheaper.
Yea.......Alum. will be HOT....plus, how would you "bond" it to the rest of the boat?JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
07-27-2009, 07:07 PM #4New Member
- Jul 2009
- michigan
Hey thanks guy.It looks like I will be sticking wood.Just trying to be a little creative.
07-27-2009, 07:26 PM #5
little b there are other materials that wont rot but it does cost a bit more then wood would
http://forums.screamandfly.com/forum...+voyager+learn
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
