Results 1 to 15 of 16
    Bendigo,Australia.
    Exclamation 260 steel bore????
    To make a 260 a non Nicasil engine you have to start with a promax 225 block??
    True or false???
    The reamining hole from the Nic sleeve is oversize for the cast bore???
    Twig.
    May 2008
    Atmore, Alabama
    There are lots of 260's running around with one or more steel sleeves in them. I know of one that is steel sleeved on all 6. Guy turns 7500 all day long, and has probably 300 hours on it so far. Good motor.
    You can even slightly bore ( 260, 280, 245, or Drag blocks ) out a bit of the Nic coated sleeve and install one of the VERY thin steel sleeves and get "some" of the heat transfer advantage of the Alum. sleeve from what Ruck tells me.....
    Jay
    Jay @ JSRE
    Sep 2002
    Panama City Fla.
    I run an all steel sleeve modified 260 and an all steel sleeve S-3000(300 Drag) on my F-1/Mod-U class tunnel boat. I won the 2006 North American Championship with the modified 260 which I assembled in 2001. I just this last month pulled the heads and tore this engine down for the first time since it was assembled after 23 races. I turn both these engines right at 10,000 RPM lap after lap. I use Advance Sleeve 3/16(thick) sleeves and have not had ANY problems. The key is proper radiusing of the ports and proper honing. We hone with 220, 280 and 400 grit stones. The engine I just pulled down have very minimal ring wear. It looked as though the engine had not finished seating the rings and had not completed break in after 23 races .If done properly there seems to be no horepower advantage shown on our Stuska Waterbrake dyno with the nikasil nor is longivity and issue. In fact the longivity seems to be far better. In the event of a scuffed piston 9 times out of ten , simple honing will put the cylinder back in shape to run not to mention you can get the top pinned Wizard pistons we sell in oversize if you do need to bore a cylinder. Can't beat the steel for longivity and saving money...
    www.eagleoneperformance.com
    Bendigo,Australia.
    Thanks guys!!
    Awsome info!!
    In my opinion a cast sleeve 2.5 with 300 Drag porting.Wizard top pinned pistons.260 style electrics.Slide fronts and a altinator set up, would be the ultimate 2.5. If done properly should run hard for a long time!!
    Being that I'm a machinist I would like to CNC port the cast sleeves before they go in.
    Twig.
    Sounds like a plan Twig !!!!! I have a .044" over steel sleeved Drag Ported 2.5 ( fishing motor ) with Horned-Case injected 14 petal 260 style front half with drag rear chest and drag sleeves installed with Wizard .044" overs installed and it runs VERY well .....
    Jay
    Jay @ JSRE
    Bendigo,Australia.
    Jay?
    When you say drag sleeves are you telling me you can buy cast sleeves with the drag porting???
    Twig.
    OH YES ! LA Sleeve sells em .. Might check with Pro Marine in Fl. they are an LA SLEEVE distributor if I'm not mistaken....
    Jay
    Jay @ JSRE
    Bendigo,Australia.
    Awsome!!
    And what did you do for a ecu on this engine Jay after all the mods??
    Twig.
    A Brucato ( ACU or PCU ) would be a great choice IMO.... (Fully programable)
    Jay
    Jay @ JSRE
    Ft. Worth, Texas
    The Drag sleeves are CNC cut
    Definately the Brucato PCU and I strongly suggest a good adjustable regulator Get the steamwheel and software, that way you can load the programs from your PC (Tony will email different fuel curves) and save time/shipping back and forth. Tony will educate you on adjustments and you should be able to "fine tune" it in no time. I run several different motors and have to tune for each one, some like 39 lb fuel pressure while others like 56 lb pressure.
    Ronnie
    Kaase Outboard Hydro/Bottle Fed 300 Drag
  12. #12
    Jun 2001
    Cromwell. NEW ZEALAND
    steel 260
    Eagle One. Do you run 41 rods or 5250 on your 10k rpm engines??? Popey
    Popey
  13. #13
    Bendigo,Australia.
    Rods??
    That was my next question??
    What are the best??
    Twig.
  14. #14
    Mar 2005
    Melbourne, Australia
    Twig, you can get nic sleeves down in heidleberg, T tops too. Get an old 2,5, pop the sleeves out, have a little play, new sleeves in and go from there.
    97STV EURO & MERC 2.5 260
  15. #15
    Mar 2005
    Quote Originally Posted by Jay Smith View Post
    Jay
    Yeah, they are, LA and Advanced.
