Results 1 to 6 of 6
Thread: Flex plate VS Flywheel
07-09-2009, 09:55 PM #15000 RPM
- May 2009
- FL
- 345
Why I am asking is is the ring gear on my 455 Olds is bad and I have not been able to find a ring gear to repair it so what would the drawbacks of using a flex plate vs a flywheel
07-09-2009, 10:12 PM #2
Flexplate!!!!!!!
Less rotating mass, engine will rev quicker
Look fear in the eyes and laugh!
If you're here to have a good time, enjoy yourself.
If you're here to be a grammar whore, troll, or arrogant nit picker then please leave now!
79' Allison GT-20
V4 OMC
07-10-2009, 09:50 AM #35000 RPM
- May 2009
- FL
- 345
looked at my drive yoke and i cant use a flexplate with out having to have a spacer made for the crank flange
07-10-2009, 06:20 PM #4
I had the same problem
I "Coonass machined" a spacer for it.
I forget what I used to make the spacer out of........... Use your imagination
As long as your spacer supports your bolts and doesn't allow them to bottom out you should be fine.Look fear in the eyes and laugh!
79' Allison GT-20
V4 OMC
07-11-2009, 03:20 PM #55000 RPM
- May 2009
- FL
- 345
Looks like a spacer will be made no ring gear to be found i think a few hole saws and drill will work making it and i have some aluminume
07-12-2009, 11:10 AM #6Junior Member
- May 2009
- TERRELL TEXAS
- 10
your boat will do a burn out. my boat has a flex plate insted of a flywheel and i will set still when you goose it.
