Results 1 to 11 of 11
Thread: Ride Plate Help
07-09-2009, 05:32 PM #1Member
- Apr 2004
- Pinellas County, Florida
- 54
Ride Plate Help
Just finished 17' CeeBee with 400HP 350.
Need to know about setup info on ride plate ?
Does plate go into bottom of hull under transome just past intake shoe ?
Thx Matt
07-11-2009, 03:54 PM #25000 RPM
- Mar 2009
- TENN
- 211
if you have a shoe installed on the intake it should/could have a step/lip machined in it the thickness of the ride plate with 4-5 bolt holes to retain the plate. this will give it a flat surface to ride on , the plates should be the width of the shoe which is usually 8 inches.
07-13-2009, 11:11 AM #35000 RPM
- May 2009
- FL
- 345
what angle should it be flat 2 degrees up or what
07-13-2009, 01:54 PM #45000 RPM
- Mar 2009
- TENN
- 211
each application is different but 0 to 2 degrees up will be real close. i see some pulled up at an extreme angle but your assumption is right on.
07-13-2009, 03:24 PM #5Member
- Apr 2004
- 54
what if your intake shoe doesn't have a place for the plate ? do i need to grind bottom of transsome so plate is flush ?
07-13-2009, 04:51 PM #6
07-13-2009, 04:56 PM #75000 RPM
- May 2009
- FL
- 345
this is how they did it on one boat i had but i would space it down more to be even with the bottom of the boat and have it right up tight to the back of the boat
07-13-2009, 07:20 PM #8Member
- Apr 2004
- 54
07-13-2009, 07:20 PM #9Member
- Apr 2004
- 54
07-14-2009, 09:15 AM #105000 RPM
- Mar 2009
- TENN
- 211
tread safely here. the ride plate needs to securely bolted as this will support most of the weight of the boat. a minor mis adjustment can result with it ripping the entire assembly off the boat or worse. this is why on a shoe and rideplate it is bolted securely in four or five places across the step. be careful
07-14-2009, 09:57 PM #11
