Results 16 to 22 of 22
06-28-2009, 08:10 PM #16Junior Member
- May 2009
- Boston MA
- 20
Yup - we are all arriving at the same conclusion. Lean misfire - a friend has another carb I am going to try but that will have to wait till next weekend.
06-28-2009, 09:06 PM #17Junior Member
- Sep 2003
- New England
- 17
Aha! I take my suggestion back, you're right its most likely the carb. Like 455maveric says you're going lean, aren't feeding fuel to match the load. Sounds like a carb rebuild is needed.
06-29-2009, 07:48 PM #18Junior Member
- May 2009
- Boston MA
- 20
OK - next question, this is a 17' 8" boat with a 455 Olds 365HP Berkley JC with place diverter, weight 1785 pounds. How fast should this boat go? Anyone have any ideas?
06-29-2009, 07:57 PM #19Junior Member
- May 2009
- Boston MA
- 20
How fast will the boat go? 1972 Marlin Leo, 17'8" 1785 lbs, 455 Olds 365 HP?
06-29-2009, 08:19 PM #20Junior Member
- Sep 2003
- New England
- 17
Probably a close match to my last boat, an 18 ft. Avenger with stock 455 Olds and 12JC-A pump and diverter. Before pump rebuild, around 55 mph. After rebuild about 58 mph.
Assuming you have an A impeller, fairly straight bottom, and reasonably tight pump, you should see mid 50's to max of low 60's, at least that's my guess.
06-30-2009, 07:39 AM #215000 RPM
- Mar 2009
- Tulsa,Ok
- 573
A lean condition will back fire, Fuel filter at the carb, fuel Pump?
06-30-2009, 01:41 PM #22Junior Member
- May 2009
- Boston MA
- 20
It isn't the fuel pump - the issue appears to be the right side of the engine only by looking at the spark plugs. The fuel filter is new. Back to the carb.
