Results 1 to 4 of 4
Thread: Got the impellar nut off..
06-08-2009, 02:59 PM #1
Finally.. But now the impellar won't budge.. Anybody have a puller in SW. Florida??? Talked to Tom from jet boat performance and it doesn't sound like a fun project ahead of me..
06-08-2009, 03:35 PM #25000 RPM
- Mar 2009
- TENN
- 211
do not beat on the shaft. i have removed many if you have a hyd press by putting the suction housing in the press blocking up the main bearing area and pressing the shaft thru the impellor for removal. plan b if the impellor is toast i have cut the impellor off . plan c i am in tenn. and have a loaner puller put it on your charge card and i will refund the full amount less fgt when it is returned. pretty easy to remove with the right puller. pm me if i can help. john
06-08-2009, 06:50 PM #3
Thanks for the offer BIGA on the puller.. I'm off to PA wed. for a month i'll worry about it when I get home the 7th.. Just for the record the impellr isn't dusted still looks really good.. hate to waste it but replacing with a stainless and race shaft..
06-12-2009, 07:14 PM #4
Put the housing in a press it it still wont budge add some heat to it. It will pop off
