Results 31 to 45 of 59
  1. #31
    Oct 2009
    more ski bee pics
    do I split the hull and deck? wondering about how to inteface new core to old core at the point just under the dash panel. much clean up work still to do.
    Attached Thumbnails Attached Thumbnails ski bee 003.jpg   ski bee 004.jpg   ski bee 005.jpg   ski bee 009.jpg   ski bee 011.jpg
  2. #32
    Sitka, Alaska
    Hey ED, If the core is dry and solid fwd of the dash, just butt the new core up to the old core and glass over it. I'd suggest using the same materials as were used from the factory. No need to seperate the deck if you're not going into the bow.
    FYI, If you're going to post your build, you should start your own thread. 71Stingers thread is getting hijacked pretty bad.
    Ron Pratt
    '91 Virage "The LAST Virage" 15" 280
    26' Grady White "fish getter"
  3. #33
    HASTINGS NE. HOME OF EBKO BOATS
    Core
    HE IS RIGHT IF YOU ARE NOT DOING THE DECK DON`T SPLIT IT, THAT WILL ALSO HELP KEEP THE RIGHT SHAPE, BUT ABOUT THE CORE MATERIALS YOU DO NOT WANT TO USE WOOD I INSIST BECAUSE LOOK AT THE WOOD IN IT NOW YOU DONT WANT TO DEAL WITH IT AGAIN 10 YEARS FROM NOW, BECAUSE ALL IT TAKES IS FOR YOU TO LEAVE A SMALL HOLE IN THE TOP LAYER OF GLASS WATER WILL GET IN AND YOUR PROBLEM STARTS AGAIN. AND GET RID OF THAT HEAVY STEEL PLATE ON THE TRANSOM.
  4. #34
    Oct 2009
    Thanks guys, I'll try to learn how to start a thread. never did this forum stuff before.
    I need to educate myself in core material, weights and types of glass, polyester resin vs Epoxy, vacuum bagging.
    most of my experience is with West Epoxy. never used core materials.
    I'll try to do some homework before getting all sticky and messy.
  5. #35
    May 2009
    Denton,NE
    Heck I don't mind the Hijack. It's all about Ebko tunnel hulls anyway. I just finished die grinding out 216 screw and rivets that secured the rub strip and then held the boat 1/2's together. They screws would not come out on their own (after 38 years, imagine that!!!) Burned up 3 conical shaped grinding bits to do it. The 1/2's are now freed up from the windshield forward. From the windshield back the factory laid cloth and resin on the inside to reinforce the joint. I now need to grind/cut through that layer to free up the rest of the overlap joint.
    Next issue will be seperating at the transom. Not sure what they did back there, looks like a bunch of resin was brushed around the bottom of the top 1/2 of the boat. Not sure what I'll use to get up there.
  6. #36
    Oct 2009
    Quote Originally Posted by 71Stinger View Post
    I just finished die grinding out 216 screw and rivets that secured the rub strip and then held the boat 1/2's together. Burned up 3 conical shaped grinding bits to do it.
    Can you show a picture of your grinding bits? After having removed the screws that way, do you feel it is the best and only way? Did you think of or try any other methods. I tried to drill my screws, but they seem to be hardened. they are the self drilling self taping type of screws I have seen which are able to be installed in steel without a pilot hole. very hard, my drill bit wouldn't touch them. I just pried one out with a wonder bar, but put a crack through the lip of the joint at the center of the hole. not something I would do for all the screws.
    I created a thread for my project its call Ebko Sprint recore. Is it possible to move postings from one thread to a new one?
  7. #37
    May 2009
    Denton,NE
    Finally got the top off the boat, wow what a job that was.
    Now I can see all the damage
    More Grinding & Time to order some end grain balsa, I think.
  8. #38
    Stinger
    How is it going did u finish ur boat?
  9. #39
    May 2009
    Denton,NE
    Not yet. Still about where I last posted. Longer, Colder, more snow than I expected. Not getting ready to go under the knife so I'll be laid up for a few weeks. When it get's back into the 40's I'll get back out after it.
    Thanks for checking.
  10. #40
    stinger
    I was wondering if u can give me a call @ 402 705 1174
  11. #41
    May 2009
    Denton,NE
    Gilbert, If you have time this weekend you could pick her up and take back to Hastings. I am having surgery on Tuesday and will be out of commission for a few weeks. Let me know what works for you.
    Rick
  12. #42
    Hi how are you i last your number u i am ready to work on your boat please call me at (402) 705 1174 if possible i wold like to pick it u this weekpleae let me know one way or the other thanks and sorry i los your number.
  13. #43
    May 2010
    branson
    1973 Ebko
    Hey All,
    I am new to this forum, stumbled upon it b/c I recently acquired a 1973 Ebko....I need to sell it, does anyone want to make an offer on it. I have no idea if it floats, I have title.
    I live in S. Missouri.
    Feel free to make offer or please let me know what it is worth if not interested or a little history behind it. Normally I would take this project on myself, but just too much going on right now
    Thanks
  14. #44
    May 2009
    Denton,NE
    GLaguna,
    Give me a call. Would like some pictures or to hear how the Stinger is coming along.
    402-770-4130.
  15. #45
    Hello guys, re doing the 69 skebee than selling it i'll post pics here if anyone is interested!!
