Results 1 to 6 of 6
Thread: 2.5 Block swap Question
08-21-2002, 10:48 PM #15000 RPM
- Jun 2002
- Lake Lillian, Minn. 56253
- 501
Can a '96 or '97 2.5 drag block be used with the components from a '98 2.5 OS engine?
Would this result in the power equivalent of approximately a newer 280 hp motor?
08-21-2002, 10:59 PM #2
Yes, they are the same parts. You will have 300 HP.
08-21-2002, 11:01 PM #35000 RPM
- Jul 2001
- Midwest
- 383
It isn't clear exactly what you are contemplating but even an early drag has pretty high rpm biased port timing and exhaust volume. A 280 isn't ever going to swing up like a drag with a 10 amp flywheel. A motor built out of drag block with 38cc heads isn't ever going be too impressive on the bottom.
08-22-2002, 09:41 PM #45000 RPM
- Jun 2002
- 501
What I am contemplating--I have very low time 2.5 260 hp motor. Want to upgrade to 280 "plus" very stock type motor. Am not drag racer--just lake racer interested in top end. Do not want to turn horendus rpm--just 8000 to 8500 occasionally. Drag motors hit peak power at 8500 which would be great.
Just viewing different options on the most $ efficient manner in which to buy the horsepower. Have located a used drag block and that is why asked question.
Are drag motors miserable idling and poor power at low rpm?
08-22-2002, 10:18 PM #55000 RPM
- Jul 2001
- Midwest
- 383
New style drags with the SVS run great, reasonable idle, super punch provided you leave the tight heads on them. The bottom gets awful mushy on a lake boat when you put on a set of 38s.
except of course N2O
08-22-2002, 10:20 PM #6
if you only plan on turning it 8500, don't waste your money on a drag block. a pump gas 260 with some work will run just as good if not better then a pump gas drag under 8500 rpm's
