Results 1 to 15 of 18
Thread: buzzer ?
05-26-2009, 11:54 PM #1Member
- Apr 2009
- menifee,ca
- 43
buzzer ?
is this right,click the key buzzer stays on,start it and buzzer goes off
05-27-2009, 12:04 AM #2
only on inboards, jet drives and sterdrives
05-27-2009, 12:08 AM #3Member
- Apr 2009
- menifee,ca
- 43
solid buz tell it starts
05-27-2009, 12:18 AM #4
What motor?
05-27-2009, 12:32 AM #5Member
- Apr 2009
- menifee,ca
- 43
220 lazer ob
05-27-2009, 12:48 AM #6Member
- Apr 2009
- menifee,ca
- 43
when you first turn the key,should it buz or beep
05-27-2009, 06:37 AM #7
Depending on the type of horn, it should have a high pitched beep if it's a merc part. some aftermarket horns buzz. Bottom line is that it should not continue to go off with the key on, engine off. It's possible you have a bad horn module on the engine.
05-27-2009, 08:46 AM #85000 RPM
- Sep 2004
- Dalhart,Tx
- 708
If you have the oil injection still on the motor it should give you a beeeeep beep beep beep. If you don't have oil injection it shouldn't make any sound. If it give you a solid beep with the motor cold you have a short in the tempsensor on the starboard head.
Shooter1
05-27-2009, 04:26 PM #9"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
03-07-2010, 07:59 PM #10Member
- Apr 2009
- menifee,ca
- 43
still does it
04-05-2010, 11:56 PM #11Member
- Apr 2009
- menifee,ca
- 43
anyone
04-06-2010, 09:05 AM #12
Check with Merc using the numbers on your module. I've found that they made a couple of different styles. Some with no test, some with short tests and some that buzzed until the engine started. I guess they were trying to satisfy the masses.
Steve Schefer
04-18-2010, 08:54 PM #13Member
- Apr 2009
- menifee,ca
- 43
it fixed its self,,,,turn the key,it goes beep beep beep then stops,start motor no beeping ,,all good ,,for now
04-19-2010, 06:31 AM #14
04-21-2010, 09:20 PM #15Member
- Apr 2009
- menifee,ca
- 43
what am i missing,is that not right
